0 Members and 132 Guests are viewing this topic.
GeoFusion
Quote from: Hoppy on October 28, 2013, 04:32:05 PM
Hi Geofusion,
Is that 3KW continuous or instantaneous?
Hoppy:
Continuous. It all matters the input voltage. but as I use the batteries to much the voltage decresses aftertime, and you will see power output also decreases.
GeoFusion
Quote from: NickZ on October 28, 2013, 03:54:52 PM
  Edit: Geo: Great news about your feed-back path, and all other information above.
Please check on how long the (smaller 12v) battery last when on the feed-back circuit, and how it does with the different loads.  Thanks.
  Here is Igor's latest tests. Please check them out.
    Tesla-ish:
   http://www.youtube.com/watch?v=sDPFGG-7G9E&feature=c4-overview&list=UUVesA155Der2tRd5vpyYdJw
  http://www.youtube.com/watch?v=FmJSirqpKco&list=UUVesA155Der2tRd5vpyYdJw
Nick:
yes saw the vids :), and also told him  I'm eager to see the last circuit drawing in work, see what it will give out.
He could be a part of the team to able to Loop things back If we get him, I will ask this man to help out too on ideas :) as I see he is very deep also in experimenting. Like that.
I will test what you mentioned. see how long it will run , that is if it really depletes the battery over time.
Cheerz~!
NickZ
  Geo: Before buying expensive caps, try to get a simple feed back path working on what you already have. That would be a MAYOR success. As the Fets can easily go up in smoke (like Grum's expensive IGBTs did) when using higher voltages, and especially higher current. We are still not providing enough kick back protection, at least not with these circuits.
  Grum:  Most people will not take the time to make the newer Akula circuits, until he can absolutely prove that it works, and not just for 20 minutes. Each version gets more complicated, and further away from what TK, Chibinidze, SR 193, and other relatively simple and inexpensive circuits have done.
  As I love simple circuits, I'm working on Geo's circuit to at least see if I can get the same results, and also include the feed back path to it.
I encourage you to all do the same.
  I'm still learning how to crawl,  before I can run.  Best part is not getting shocked, and still able light 100s or 1000s watt worth of bulbs. If and when possible...
Khwartz
Hi Geofusion,
Dear Hoppy.
Until now, having not seen any accurate measurement, how could Geo says it has 3 kW of out put power?
Have seen yourself these measurements? If I have missed them, could refer me to them? Cause unless it is done, we all make hope on approximations which could be underunities.
And seeing how it goes, looks to me that light bulbs are indeed bad way to test o.u. for non-professional as the temptation is too great to only make the half of the work and "stay blind by the light".
So my conclusion is pure thermic linear resistor tests, by checking of temperature, would provide the enough rigour required for such experiment.
What do you think?
GeoFusion
Quote from: NickZ on October 28, 2013, 04:55:58 PM
Hi Nick :),
Yes true that man, buying those expensive  stuff might help alot, especially what I mentioned about the way i visualised it.
and yes it would come out as a mayor success for sure.
Yeah Fets are very fragile with this work, Oh? that is sad, waw IGBTs, would like to get some.
Yeah well, it's always to try out higher inputs to see what it does and I think only higher voltage is needed, amps should stay at the same.
that is what I miss too, Protection of the Kick backs that the system gives. Have to somehow figure out something, but I saw something new today while busy with it.
It will be in the new uploaded vid.
Btw I was busy uploading on of my newer vids RMG part 2. but without measurements for now. It will all come.
Khwartz:
This is not for the roundcore this is for the Newer version of it. I haven't done anything more on roundcore up till now.
but the newer one RMG ( Resonant Magnetic Generator ) .
the RMG  can up to 2-3kW of on lighting light bulbs of sorts of ratings, I really did not measure via meter or so what it could be yet. But when i say those outputs it's eq. to so many lights connected.
only on  36V I could reach that amount, but now on 24 i'll reach 1.5kW on lights. Might be not evenly bright as mains but when 36 Volts is connected it will be bright or brighter then mains.
Measurements will come, My equipment will be arriving soon but I'm really focusing on the self run ability and able to produce more without getting the Fets fried.
As for now I really don't have good measuring equips with me now, only that clamp meter but it helps a bit,.. doing this by feel and understanding the working of it.
Experimenting can be dangerous but it's worth it.
Btw the bulbs are extremely hot.
Cheerz~
