0 Members and 132 Guests are viewing this topic.
stupify12
Quote from: verpies on October 28, 2013, 02:51:08 AM
Yes.
The PJK ebook had some ideas in it how to divert the reflected flux away from the primary.
Tesla 8) has a way to divert the reflected flux away if you term it like this. Tesla 8) called it delay or magnetic lag. The purpose of magnetic lag is for retardation of the magnetic flux to make the phase shift of the Secondary coil into 90 degrees. People here already knows that the Phase Shift 90 degrees= In Phase :o ::). So This is MAYBE the secret of Kapanadze he was talking that is so SIMPLE. :P
Look for the CLOSE MAGNETIC CIRCUIT=IRON PLATES AND IRON WIRES-CLOSE LOOP on the main COIL. HAHAHAHA LOL ;D ;D
Meow ;D ;D
GeoFusion
Hi guyz  :)
check this one out:
Tell me what you guyz think about the possibilities.
Part 2
http://www.youtube.com/watch?v=ac1ptZFRelo
Enjoy
NickZ
  Geo:
  I just saw your part 2 video, and it is showing just what I was hoping for.  I will also test my circuit (when I get it fixed up again). And I also have some of those big iron core battery back-up transformer, which can be use to step up, or step down the voltage. The main thing is to focus on the amps, as voltage is easy to obtain, but not amps.
  I tossed out the two fans that did not work even connected to my Pc mother board, and found another one that is working just fine. I also found two more Fets,  IRF 630, and 634. So tomorrow I'll be putting together another Royer circuit using those Fets, as well as the cooling fan.  Then will also try the big iron core transformers, like you are using, as well.
Thanks for showing us your part 2 video.  Looks wary interesting...
  Keep up the good work, and do try to invite Igor over here, as well.
Hoppy
Quote from: Khwartz on October 28, 2013, 07:37:24 PM
Dear Hoppy.
Until now, having not seen any accurate measurement, how could Geo says it has 3 kW of out put power?
Have seen yourself these measurements? If I have missed them, could refer me to them? Cause unless it is done, we all make hope on approximations which could be underunities.
And seeing how it goes, looks to me that light bulbs are indeed bad way to test o.u. for non-professional as the temptation is too great to only make the half of the work and "stay blind by the light".
So my conclusion is pure thermic linear resistor tests, by checking of temperature, would provide the enough rigour required for such experiment.
What do you think?
Khwartz,
As has been emphasised earlier in this thread, power levels need to measured and not just assumed from lamp brightness. A true lamp power dissipation of 3KW continuous is not going to be produced in mine or from the Royer setups I've seen in Geo's videos.
GeoFusion
Quote from: NickZ on October 28, 2013, 09:26:44 PM
  Geo:
Hi Nick :),
Thnx for taking some time to see what I've come across what I have recorded.
After the loop is working, will start working on the brightness of the lights adding a few caps in resonance to hold.
Alright, be carefull though, when connected to the transformer it becomes deadly, I think death can be achieved here easily, if not safe. Yes Amps are what should be focused on, but that wont be a problem :), It's all LC that will do the trick.
Ahh, thats good news, Yes because sometimes other PC fans work differently then others.
Awesome, be carefull not to blow them to fast lol, Alright.
No problem man, Showing what progress is made and what possibilities are available.
I might Soon share my RMG schematic too for you guyz to try out and for further progress.
Yes I will get him here very soon, have to get him again.
Cheerz ~
