0 Members and 570 Guests are viewing this topic.
GeoFusion
This looks so interesting yet so Easy in my way of seeying it, I might try this one soon too.
reminds me of my SG Tesla coil.
http://www.youtube.com/watch?v=5nxKqfkkndw&feature=c4-overview&list=UUbcaIfmxRZhnnYVqG81kCZg
This is All compilation, awesome.
http://prezi.com/fiwgtl78it85/donz-device/
Thaelin
NickZ:
   Be on the lookout for old UPS backups say 800va and above. I just tore down
a 1000 and bhold, there was 27  200v 52A Fets in there. Bit of a chore to get at
them but in the end worth it. Usually, the batteries die and it is cheaper to replace
the whole thing than batts. This was a 36v system and worked but just really old.
I built a small royer with them and it runs quite cool.
MenofFather
Quote from: GeoFusion on October 29, 2013, 10:32:24 AM
Cubinadze so called video, originaly be posted on 1 april other man, I wery bealeave that is just joke of 1 april. I know that men, he not seems that have FE divice, he searching also like and others.
Khwartz
Quote from: GeoFusion on October 28, 2013, 08:10:19 PM
Khwartz:
This is not for the roundcore this is for the Newer version of it. I haven't done anything more on roundcore up till now.
but the newer one RMG ( Resonant Magnetic Generator ) .
the RMG  can up to 2-3kW of on lighting light bulbs of sorts of ratings, I really did not measure via meter or so what it could be yet. But when i say those outputs it's eq. to so many lights connected.
only on  36V I could reach that amount, but now on 24 i'll reach 1.5kW on lights. Might be not evenly bright as mains but when 36 Volts is connected it will be bright or brighter then mains.
Measurements will come, My equipment will be arriving soon but I'm really focusing on the self run ability and able to produce more without getting the Fets fried.
As for now I really don't have good measuring equips with me now, only that clamp meter but it helps a bit,.. doing this by feel and understanding the working of it.
Experimenting can be dangerous but it's worth it.
Btw the bulbs are extremely hot.
Cheerz~
Understand, but still you can have a false idea of the power out if not proper comparition.
Measurement doesn't need sofisticate nor expensive and I do not understand why so few experimenters can't even just light the same light bulb with main power aside the output load light bulb. Who can say it is "too expensive" or "complex"! Nevertheless, near nobody does that, and I am very afraid that to avoid to face the result :/ while you just need very cheep Amps and Volts meter for your DC imput.
Of course, if you can selfrun it, WITH CAPS EMPTY AT THE BEHINNING OF THE CYCLE, and unplug from the earth, there will be no mote discussion. But much more delicate to do and complex than just lighting a "reference bulb" ... ;)
Cheers.
NickZ
  Ok, just finished my new version of the Royer circuit, using two different Fets, the IRF 630 and another IRF 634. Also two 1k resistors, and one 0.33uf poly cap. Trying to get as close as I can to replicate Geo's circuit. This time using the Pc fan.
  But, the results are just the same as before, able to partially light a 50 watt bulb, or two 50 watt bulbs, but not the 100watt bulb. Nor a 50 watt and also the 100 watt bulb. So, looks like I'm going to have to add more winds on my yoke's secondary (red) coil.
  Circuit still get very hot when not using the fan, and lighting two bulbs. I can't imagine what the heat would be like when using even more bulbs, as I don't see the draw going down with each added bulb. Going by the heat generated from the Fets, not meter readings.
  Thaelin: Thanks for the tip, yes, I have several of those older Pc battery back-up units.
But, the ones that I have use the transistor that I mentioned in a previous post.
  Geo: What is the reading of your Yoke core device at the output coils, with and without a load (one 60 watt bulb as the load)?
  Edit: By adding more caps (0.33uF to 0.47uF) to the primary coil side of the oscillator, the bulb brightness lessens, by removing ALL caps the brightness increase by about 20 %.
But the heat issue is not sufficiently resolved by the Pc fan. And the heat-sinks become untouchable only after a couple of minutes run time.
  Please feel free to PM me, if you don't want to post on this (public) site.
