0 Members and 211 Guests are viewing this topic.
a.king21
Quote from: Grumage on October 29, 2013, 04:27:12 PM
Dear All.
The saga continues!!
I apologise in advance for the poor quality. For some reason I could not upload an HD version!!
https://www.youtube.com/watch?v=noMjg5fu77M
For Verpies. The oscillations are heard despite the fact that the two halves are separated. So I think the Ferrite cores are acting like little speakers.
Despite the massive voltages seen on the scope the 21 W 12 V bulb does not blow but when connecting to a standard 240 V bulb, no light is seen at all!!
Cheers Grum.
I think in repulsion mode you were getting acoustic resonance which explains your power gain and also you were disturbing static which explains the electric shock on the core and your fluoro lights getting affected. If you use an earth ground inductively coupled you should also see an energy gain during repulsion mode.
All you need is an EV gray tube to pick up all that static and you are away.
I bet you would also light a neon bulb up at 2 feet with no direct link except an earth (or your body) lol.
I think you just may have made scalar waves. lol
Khwartz
Quote from: GeoFusion on October 29, 2013, 04:58:13 PM
Hi Nick :)
Oh uhm, I measured last from the output wires Without Load connected it's something inbetween  160V~ 140Vac from those ouput wires, sometimes when turning it on and off and on again fast it jumps all the way to 180Vac but that is also something with this oh well..
When the bulbs are connect and using the 12 V, they are not so bright, guesing 60-70% brightness of what mains gives out.
When I connect the 100watt bulb it goes to @135V~ when i connect the second 100watt bulb it jumps back to 140V something, When connecting the 3de 100watt, Voltage becomes @120~.. so again Odd behavior the roundcore does or as we know already we cant measure this type of energy with common meters, Igor told me about this too.
Well Sometimes It increases and sometimes it decreases for me when using more caps or not. Depending on the load I gues.. It does let me put more caps when more load is connected but if les load is connected, les caps for brightness. Odd right? haha
Cheerz~
That's why it is so important to focus on "Real Power" to estimate the COP.
Why we need o.u. devices? It is to be able to power our houses, so by Real Power (Watts).
The currents and voltages in these kind of devices have always shown up as very complex. Complex frequencies, high frequencies, and yes, to understand and optimize only scopes will do.
But again and again, if about to demonstrate o.u., it is far far enough to just show an REAL output power by very clear, sumple and obvious means. Even said "true RMS meters" will not do not scopes otherwise. But scope are much more complexe to read and make others understand.
So still the same recommendations: reference light bulbs (or thermic measurements).
Cheers.
GeoFusion
Dear All.
Cheers Grum.
Hi Grum :)
About the new vid Awesome. ;D
Don't worry about the quality to much now Grum, it's what you have figured out and it's something extreme haha.
As seen, really looks like Acoustic Resonance that does this job and makes this happen.
Very sure that this output can do some serious damage sins it's direct with input coil and all the way to output :). so careful mate.
I could imagine that voltage but, try it on a halogen of any wattage rate, and raise it to a halogen of a greater wattage like a 100 Watt or more or less to see what it does, Sins it lights up that 21W 12V bulb like that why not trying it on those for a test :).
thnx for sharing
Great job
Cheerz~
ARMCORTEX
Very bright light for 24*2.65 amps. You should have taken a 100 watt mains and compared.
Overunity lumens for sure.
Right there, you could probably make a doomsday garden and manage with a much smaller than usual solar and wind recharge external input.
Basicly the essential for life is , heat, light , internet connection maybe ?
Dont need a fridge, nuclear winter is cold.
ARMCORTEX
Right there, you could probably make a doomsday garden and manage with a much smaller than usual wind recharge external input.
