0 Members and 812 Guests are viewing this topic.
forest
verpies, where is your palusible MO ?
tagor
Quote from: ingyenenergiagep on November 04, 2013, 01:48:27 PM
173kHz.
Moray wrote 186kHz.
If the triple frequency makes stronger resonance in ferrite, we need about 519-558kHz sinus driver(and/or serial wounded, "bifilar " coil on resonace freq).
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/129444/
this schematic was posted on the kapanadze thread here ( 29 october 2011 )
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg303920/#msg303920
... 2 years ago ... but have you read this thread :
http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/#.Unin26yweFA
are sure this is a working one ?
itsu
verpies,
thank you for your comments, they are welcomed as always.
However, at the moment i am commenting on the many reactions i got on my video's
about changing to other chokes, yokes, caps, MOSFET's etc. to get the wanted effect.
This wanted effect is what GeoFusion showed here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg373333/#msg373333
being able to light a 1000W halogene bulb with only a 12V / 1.3 Amp. battery by using "cold electricity".
Even after changing severall recommended parts (choke, MOSFETs, caps) i have shown that
in essence it does not change much in obtaining the wanted effect, as both in "normal mode"
and in "special mode" the input is much more then the output.
(i roughly estimated when using a 60W / 220V bulb, i have almost 70W input (mean 11.49V / mean 6.07A)
while the bulb itselve lights up about 40% (24W).
So my idea is to first get the wanted effect replicated and then try to find out what it is causing.
Regards itsu
MenofFather
Maybe for somebody interesting. I made transformer HF about 12 V to 12 volts. input square 50 prec. duty cycle. Primary and secondary on yoke about 30 turns, primary and secondary 2.5 mm2 cable (acustic cable). Lamp 55 W 12 volts. Brightness full about, same like from battery 12 V in some modifications maybe and brighter. Parallel capasitor to primary 2 uF, try and 0.3 uF and without capasitor, big diference no, can find optimal frenquency with any modification. Imput about same like and output power. With load about 12 volts and 4-4.5 amps (in some cases 10 V and about 5-5.5 amps (with 2 uF capasitor, then without load small power...)). Without load 19 V and about 0.4-2 amps, depending that frenquency regulate and of some modifications. I using energy from transformer, so voltage drops, then add load.
verpies
