0 Members and 753 Guests are viewing this topic.
MenofFather
Quote from: itsu on November 05, 2013, 04:41:17 AM
verpies,
thank you for your comments, they are welcomed as always.
However, at the moment i am commenting on the many reactions i got on my video's
about changing to other chokes, yokes, caps, MOSFET's etc. to get the wanted effect.
This wanted effect is what GeoFusion showed here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg373333/#msg373333
being able to light a 1000W halogene bulb with only a 12V / 1.3 Amp. battery by using "cold electricity".
Even after changing severall recommended parts (choke, MOSFETs, caps) i have shown that
in essence it does not change much in obtaining the wanted effect, as both in "normal mode"
and in "special mode" the input is much more then the output.
(i roughly estimated when using a 60W / 220V bulb, i have almost 70W input (mean 11.49V / mean 6.07A)
while the bulb itselve lights up about 40% (24W).
So my idea is to first get the wanted effect replicated and then try to find out what it is causing.
Regards itsu
I not think that geofusion get something special then light 1 KW. Because he light on so small brightness. Then here no one kilowat, but maybe 20-40 W. Better light smaller load, but in full brightnes, then we know, that exatly output power.
verpies
Quote from: forest on November 05, 2013, 02:41:39 AM
verpies, where is your palusible MO ?
In my previous posts.
In summary: magnetically confined, coherent beta current spikes arising from NAR or NMR stimulation of the core.
The first step of the former, requires the precise identification of the fundamental acoustic standing wave frequency (FASWF) of the core and setting the electric LC resonance frequency (LCRF) of the primary winding to ½ of FASWF.
A second major step in the tuning process is the adjustment of a static (or LF) magnetic flux density (B), permeating the core in a direction perpendicular to the acoustic displacement motion, in order to satisfy the relation B=2π*FASWF/γ.
Grumage and Itsu are already doing the latter by blind manipulation with a handheld permanent magnet.  Unfortunately its magnetic field is neither homogeneous nor correctly directionalized, not to mention the proper flux density at those frequencies.
verpies
This wanted effect is what GeoFusion showed here.
So my idea is to first get the wanted effect replicated and then try to find out what is causing it.
Maybe, just maybe, that would be possible if you had exactly the same ferrite as GeoFusion and his scopeshots.
verpies
Quote from: MenofFather on November 05, 2013, 04:53:53 AM
I don't think that Geofusion has anything special when lighting 1 kW bulb because his light has such small brightness. There is no 1kW there, but maybe 20-40 W.
I agree that visibly lighting a 1kW light bulb does not mean that 1kW of power has been delivered to it.
Video camera evidence of light intensity is not credible.  A simple Wattbox a la Grumage's, would be, though.
forest
verpies you are overcomplicating simple process  ;D
any ferrite  is good if you know what to expect
damn, I wish I could have better constructing skills....
