0 Members and 71 Guests are viewing this topic.
Osiakosia
Quote from: d3x0r on October 08, 2012, 11:15:48 PM
what is the flow of electrons in the cylinder?
I REALLY like this resonant frequency calculator, can give any two, leave third blank and it works.  It's a self contained script also, so can rip to standalone.
http://www.whatcircuits.com/lc-resonance-frequency-calculator/
Please find very interesting and usefull site with numerous calculators for LC circuit
and EM waves propogation .
Want recomend for all OU resechears .
http://www.amanogawa.com/Circuits.html
verpies
Quote from: d3x0r on October 09, 2012, 01:24:11 AM
But anyway, how do I keep L1 from being a 0 ohm load that consumes all of the pulse from the toroid?
@d3x0r
Before I can help you, I must know which schematic diagram you are using to build your circuit.
There are many versions floating around.
Please post a link to it. For example see here...
d3x0r
(Added video links)
Quote from: verpies on October 09, 2012, 03:05:38 AM
@d3x0r
Here...  Actually the post after yours....
But in either case, 4 of Tr2 is connected to L1 directly, which saps all the power.
(these are some of my testings... )
http://www.youtube.com/watch?v=LxyfKbh6Loo
http://www.youtube.com/watch?v=M482imX3L78
verpies
L1 is now 3.02mH (+.64)  (28 turns/cm  17.8cm, 498 turns, Dally spec 475, (needs minus 21, or 1cm-oh good, thought I was short )
Because L1 has an inductance of 3.02mH it means that it resists 4.6kHz AC sine wave as much as an 87Ω resistor (a.k.a. impedance).
Because W4 of Tr2 outputs a 4.6kHz rectangular wave, then this impedance is lower because a rectangular wave also consists of many additional higher frequency sine waves (says Mr. Fourier). Approximately 71Ω
So the question becomes: Why W4 of Tr2 cannot handle a 71Ω load?
Do you enable any other loads on your secondary windings?  If yes then disconnect them and report what happens.
Black_Bird
@d3x0r, verpies
In Dally video, observe that he turns on the inverter first, then the nano pulser, and then the load. Maybe it is a problem of inrush current at power on. In my setup, I use a different inverter, that presents a similar problem. The nano pulser frequency has to be adjusted to the resonant frequency of L2 and C at the vco. The inverter frequency does not need to be at that frequency. What I can see on my setup is a 4.6 KHz sine wave with a smaller wave riding over it. I still cannot get a reasonable amplitude, but the effects are there.
