0 Members and 938 Guests are viewing this topic.
skywalker66
@Nick
Nick is obvious, Igor is not interested in closing the loop and presenting a selfruner publicly, if doing so, then game is over for him...is a dangerous business to go forward and fully disclose a such device. But he continue to show more clues, leaving you to do the rest of work.
Hoppy
Quote from: skywalker66 on November 26, 2013, 07:59:16 AM
Did you see this vid of Igor: http://www.youtube.com/watch?v=Zp9KgQPlP28
if not, look closely because he get something there. This vid is very relevant for our research here. But as usual no one here pay attention on valuable clues.
Yes, I've seen this video and I did watch it carefully. I could not see the battery ammeter scale, so do not know how much power the device was consuming. His output measurement of 196V / 1.5A may or may not be accurate given that he is measuring HF current. What do you think he has got there and why?
Grumage
Quote from: NickZ on November 25, 2013, 05:49:03 PM
    Dear Grum:  I have two big power transistors #E13009L. You had previously mentioned that I should try the Royer or Mazzili circuit using TIP 3055. I have those also, but thought that maybe the bigger transistor might hold up better. What do you think, and how should I connect them up? As, I've run fresh out of Fets to play with for now, and would like to keep tinkering, as that is what keeps me active and thinking.
   Thinking and tinkering...
                                         NickZ
Dear Nick.
The transistors appear to be high speed switching, see here for the spec. http://pdf1.alldatasheet.com/datasheet-pdf/view/53466/FAIRCHILD/E13009L.html
I would think they should work well!! My pair of MJE 15030 have done many hours without "Flaming", YES they get warm so keep an eye on them.
Now some musing. GeoFusion's original "Simple" circuit relies upon a resonant LC for the primary. Could it be that he has, possibly by accident also found the Ferrite cores natural Ferro resonance??
This effect alone could explain the apparent gain!! I have been doing a lot of experiments (Stone age ) according to T-1000!!  :) Banging the rocks together!!  :) And there is a voltage generated at the materials natural resonance. Loose coils appear to work better, they allow the core to vibrate. I know Verpies picked up on this!! The split orientation also seems to play a part.
For my part if stone age works then give me a BIGGER hammer!!  :)
Cheers Grum.
skywalker66
Quote from: Hoppy on November 26, 2013, 08:16:18 AM
Not carefully enough. Please watch again especially at the moment 5:20 he tell the input meters shows 12v/7A.
In regard your last question, isn't obvious ?  He light nearly full brightness 2x300W light bulb using merely 12V/7A input. I don't know about you, but for me that is called a evidence.
Hoppy
Quote from: skywalker66 on November 26, 2013, 09:34:09 AM
All hands to the bench then!
