0 Members and 594 Guests are viewing this topic.
GeoFusion
Hi Guyz :)
ARMCORTEX:
Thnk you. :), yes it would help many ppl if they work on it. It gives massive ideas and for further Developement.
Btw there is nothing hidden of what I am showing you all,  it's all to try out and see for your self.
You must have the guts to experiment and try out without fear, only so progress will come out.
Simple machines are everywhere, just the right knowledge has to be obtained
I'm not here to make money with this, My mission is to make this all Free to anyone for a better future and advanced one. All together as one :)
Guyz i have uploaded new vids Of what Igor made some years ago, TROS system :)
this brings to the idea how the ground works and the add working of Variac parallel connection to it.
Enjoy
Part 1
http://www.youtube.com/watch?v=WcnJnJ7YnL4
Part 2
http://www.youtube.com/watch?v=Vz_MP3vW-2c
Part 3
Is coming out soon, to show how it works with water and lighting up CFL's very bright and will stay on for months.
Cheerz~  ;D
a.king21
GeoFusion:  I have a method  to measure your battery when radiant energy causes the bouncing effect.
1 Measure the start voltage with the system off.
2 Run the system for 1 minute.
3 Switch off.
4 Measure the voltage with the system off.
5 Keep repeating the process.
Simple; that way you get feedback information to help the experiment.
magpwr
hi Geofusion,itsu
I have uploaded my first video on roundcore/yoke replication.
I was unable to light my 1KW 220v halogen tube which i have purchased for Project Gene shown in JLN Lab.
The only good news is i have not destroyed any 600volts mosfet at this moment.I'm using 4.8Volts for ZENER and 1KOhm instead of 470Ohms.
I 'm merely using electrolytic capacitor 2200uf to smooth out 12volt supply input.
Although i was unable to light anything i was amazed how this yoke can run at different frequency upon shorting output.Do watch the video to get a clear picture.
http://www.youtube.com/watch?v=_K-9Ir7W398
Need expert advise on how can i improve the output.Thanks in advance.
The yoke winding spec is 27 turns for output and 8-0-8 turns for input.
Is the yoke half insulated for example?
GeoFusion
Hi there guyz  ;D
a.king:
Yes, i will try that method :), ty. I will make a 4th video about it also or just to let know here on thread about the measurements with pictures. thnk you for letting me know. other wise I should get some analog meters might work xP
magpwr:
Hi :), I have seen your Uploaded vid of your replicated Roundcore.
I really am starting to like your version of Royer circuit sins it has those 600Volt mosfets that are hardcore and can handle presure. I should start looking for them xP.
By the way, I think your Royer Circuit can handle 120Vdc input (= or a bit less voltages around 60Vdc or so.
I have a schematic of it where 500V 44A mosfets are used instead of the IRFP250's or IRFP260's where it can work with 120Vdc! just imagine what the output would be If I managed things with 12 to 24 volts only XD!!! haha masssive output.
Hmmm Might be that your core is not properly set for it to produce energy with acoustics.
The windings seem ok, 27 and 8-0-8.
Both halfs of the yoke is insulated, Both half pieces.
!!Important!!:
one layer of paper or tape inbetween the 2 splits of the ferrite yoke. That is needed for it to function :)
Guyz, I have upload the Part 3 Video of Igor's TROS system MOD.
Might come in usefull information and capabilities of Radiant electricity usage :).
Part 3 :Igor's TROS system Mod part 3 With water, CFL's and Motor
https://www.youtube.com/watch?v=FD8FcUKo-tY
Enjoy
Cheerz!  ;D
Khwartz
Quote from: a.king21 on December 01, 2013, 04:55:54 AM
3 Switch off.
So relevant and brilliant :d
