0 Members and 594 Guests are viewing this topic.
NickZ
  Geo and All:
  Ok, I'm a bit confused as to the last video showing the 2n3055 circuit. This is a complete change in what we have been working towards, and I don't understand why it was even shown. The most that circuit can do is to light a 100 watt bulb very weakly, while overheating the single transistor. Or not???  It's a basic JT circuit with a slightly modified "Joule Ringer" core".
And yes, it shocks.  So...
  What I have been hoping to see is a circuit that can self-run. And so far, I have not seen any circuit able to do this. So, if we can't show proof that these circuits can self-run, then aren't they nothing more than just over simplified inverter circuits? Which by the time you add the additional draw caused by the cooling fans, etz... what do we have???
   So, far neither Igor, nor GeoFusion, nor, JB labs, nor anyone else has been able to show these circuits "self running".  Why NOT? Isn't that what this is all about?
Not just another inverter circuit?
  So, if there is anyone with a properly working Royer/Mazzili circuit, that can take the time and effort to LOOP the circuit, and SHOW it self running, it would be most appreciated. As months are passing and no advancements to be seen.
Hoppy
Quote from: Grumage on December 02, 2013, 01:13:09 PM
Evening Hoppy.
What?? tougher than John Wayne ?? But seriously no I have not. They do have a good Voltage. Is this something you would recommend??
Cheers Grum.
Yes, in my opinion they are more robust with a better spec than the 2N3055 for our type of experimenting. I've used many of them in Bedini device experiments.
Hoppy
Hoppy
Quote from: NickZ on December 02, 2013, 01:30:47 PM
A good question Nick! Needless to say, you know my answer.
NickZ
  I have a pile of dead 2N3055 also, which are not very hardy, and not at all like John Wayne, who is also dead. The bigger they are the harder they fail.
My last big twin transistor Royer circuit was proof of that. I wish that I had made a picture of it, when it lit on fire, and filled the room with smoke.
  "Lasersaber" buys the 2N3055 in lots of 40 or more at a time. Can you imagine why he would need to do so?
   BWT: What can you do with them? Like, can you loop them? NO?
  EDIT:
  Yes, Hoppy I know your answer...  But you are not here just to spot x-wires, or are you?
We know that somehow, this is all possible. Maybe not easy to do, but doable. Why it has taken everyone years to do so, is beyond me.
Again. we need to focus on a stable circuit that WORKS, (not just for a minute or two), and that can be LOOPED.   Right???
Khwartz
Quote from: GeoFusion on December 02, 2013, 09:11:08 AM
Hi  Guyz   ;D
Khwartz:
Hi  ;D Yes I'm back and all ok haha.
Ahh electrician :), that is awesome, we need some people like that on the field of Motor/Generator. I am but a mix of Electrician and for small adv. electronics repair and experimental (=.
OK :)
Sure, :) I will be posting on the Thread too, Pictures
I meant pics of the "identification plate" or "motor labels".
Quoteand Videos of this 100% working device. Yet a very simple one, I had no idea It could be Done like that, But a great relief and my house works on it  :).
Understand! And how many kilowatts do you take on to power your house indeed?
QuoteI could start mentioning some specs of another one I made ( motor/generator )
it's a 120Vac Motor, 3400 RMP ,1/3 Hp
Generator - Brushless 2.5 KW 120Vac , 220Vac,
So what looks interesting here to me, is the very huge ratio nominal power of the gen under the nominal power of the motor: 2500W/(745W/3) =~ 10.
QuoteLooks to me too that one is giving the RPM with low power consumption and the other the power from the RPMs. Can't wait to see these labels motors.
But this one I connected a belt with pullies. :)
Switch in between the output of the Gen and motor for the Gen to feedback the Motor, Make sure your gen produces the Hz that the motor needs! very important, like mines are 60hz, and needs to produce 60hz as it spins :).
as  fabricated as it was earlier on a gasoline engine hehe.
Makes rather sense to me from the hertz.
QuotePrevious  Generator of 4KW is with direct shafting, but I think I'm limiting my self there sins you could put more connects of you use belts and pullies like a Flywheel  , but it's great of use!! xD
OK, Geo, thanks for specifying here too.
