0 Members and 938 Guests are viewing this topic.
Hoppy
Quote from: NickZ on December 02, 2013, 02:06:27 PM
  I have a pile of dead 2N3055 also, which are not very hardy, and not at all like John Wayne, who is also dead. The bigger they are the harder they fail.
My last big twin transistor Royer circuit was proof of that. I wish that I had made a picture of it, when it lit on fire, and filled the room with smoke.
  "Lasersaber" buys the 2N3055 in lots of 40 or more at a time. Can you imagine why he would need to do so?
   BWT: What can you do with them? Like, can you loop them? NO?
  EDIT:
  Yes, Hoppy I know your answer...  But you are not here just to spot x-wires, or are you?
We know that somehow, this is all possible. Maybe not easy to do, but doable. Why it has taken everyone years to do so, is beyond me.
Again. we need to focus on a stable circuit that WORKS, (not just for a minute or two), and that can be LOOPED.   Right???
Nick,
Although spotting potential and real 'X' wires is fun and does take up some of my time, I do spend a lot of my time as a retired old git experimenting and have a well equipped bench for that purpose. I've been at it since I was a youngster and I have learnt to smell a rat in all those years! Rest assured that I will report anything interesting from my experiments, which I am doing behind the scenes, if and when I observe any.
The reason self-running is taking years to discover and is still ongoing IMO, is that its either not - simple you'll laugh;  :) or much more likely its not possible, so you will never laugh.  :(
NickZ
That, did make me laugh.
  Almost as much as when my last circuit went up in smoke.
Edit:
  I've included the close-up of my last replication of the GeoFusion's first "round core"circuit, along with the original diagram that it was taken from.
  Also the third pic of my best working Fet version lighting 60 watt bulb...
  Hopefully we can see Geo's replication shown or pictured in the same way (close-up).
Now that we have his latest diagram to work with.
  I've already made about 6 or more different versions of his circuit up to now, but, I still need to find the right Fets for the job, then tune for the best output by changing the  yoke core windings, to obtain the brightest bulb lumins.
GeoFusion
Hi there guyz  :)
I see alot of confusion and desperateness in comments here now.. Please be patient.
All what i show is what I have done and also discovered as progress in many ways and ideas that can help everyone.
The idea is to bring knowledge together to bring about something greater with other knowledge to it.
If replications fail, is because they are not replicated " Precisely " as what is shown.
There is no X-wires or magic tricks involved in what i do, it's all natural with the earths electric field.
It's all there and if more details are needed I will give, I wont be a problem and I don't even mind.
magpwr:
Good luck with the new testings! :), Yes I also tried it on HV transformers like the flybacks, on even 24Volts and 36volts.
It arks like 20cm long arcs!! very deadly. Yes I'm guesing low ESR Rating should be worth a try for good results but the resistors play a big role remember. So yeah  ;D try the more winds on, see what it does.
Grumage:
Yes Grum  ;D I will post the Schematic of the TROS system with 2n3055 and make it good to post on the Forum.
Oh yes they are very tough :P, i like to play with them when they are on a flyback for high voltage outputs. by putting even 24 to 48volts to them :). Massive Kilovolts!
Haha, yes Iron and Copper  conductors, that is the trick of this coil :p, copper functions as the positive and Iron as negative flow of radiant energy ( Kapanadze Copper tube and radiator Iron/aluminium )
Same as how we can put Copper tube in ground and Iron tube in ground next each other, salt water on them, and get positive and negative leads, DC power. :) that was the Idea hehe.
Nick:
Hey man  :-\, it's only to show other possibilities that I have.
don't wrry the RMG will self run, just waiting on my Caps and high amp and voltage rectifiers. otherwise it wont work!.
Btw the 2n3055 circuit, can run on 24 to 36 volts, and gives up to 600 watt energy on 36Vdc. :)
Nick, the Roundcore Experiment, is not all that, it was to see the potential of acoustic resonance. but I did not continue it because it would take alot of time figuring other possibilities out, burining alot of circuits, and yet the output I could not short them because it would put the circuit go in smoke instantly.
selfrunners are not easy sins I have burned alot of circuits befor but I have run some circuits, including the RMG  but cannot handle more then 7 hours.
it's all research and experimentations, if you really want free energy now and self feed and easy, make the motor/gen. :) simple.
Khwartz:
I will soon make some pictures of the motor/gen and vids for you to see and for others :).
and specs and everything els.
Yes the Hertz are very important! :)
Be safe all, please keep a positive mind, I know everyone is in a hurry with this, but in a few months there is visitation of our Other planetary Friends :) prepare!.
Cheerz guyz :),
GeoFusion
 8)
Use this circuit. it's wicked.
Imagine my RMG on 24Vdc, is putting 2KW on lighting bulbs using the Royer circuit, Imagine 100Vdc to 120Vdc of this one and to see load. Magnificent! ;D
would be enough energy to Self run without a problem ;), but the coils of the transformer needs to be thicker to handle the massive amps.
Cheerz
Hoppy
Quote from: GeoFusion on December 03, 2013, 01:19:20 AM
Hi there guyz  :)
Cheerz guyz :) ,
Yep, 1 April AM next year is the scheduled landing date. They will be giving us the real plans for a working self-runner based on energy transmutation (ET) technology.  ;D
