0 Members and 698 Guests are viewing this topic.
magpwr
hi Geofusion and everyone,
I have just uploaded my latest video into youtube.I have manage to reduce current draw from 5.2Amp down to 3.6Amp (56watt down to 40watt) and maintaining similar brightness. :o
As usual i'm using 4 turns at output to limit current to Halogen lamp so that circuit would be able to go into ringing mode.This was not mentioned in video.
GeoFusion roundcore replication attempt v3.0
http://www.youtube.com/watch?v=33de6HV3F1I
I'd believe i have hit physical limitation for this small yoke which was extracted from a 14inch TV.I need to find bigger yoke.
I have purchased 1.5mm sq diameter ,7 strand wire for secondary so that i'm able to increase Secondary winding from 27 to 40 for this small yoke.Previously i was using 2.5mm sq for secondary winding.
I'm still using 2.5mm sq diameter wire for primary with 13-0-13 turns for v3.0.
I think due to yoke ferrite size the power output is limited once the circuit is kick started to ring by reconnecting power supply wire.
I'm using watt meter as seen in video to monitor power input if power input is around 220watt upon powering up i quickly disconnect and reconnect until the circuit start to oscillate properly at lower power ~40watt for v3.0.
By doing this i avoid smoking any mosfet at all.That's was my secret.  :D
I think this yoke once set to go into ringing mode can be a part of  Akula device.
I have just placed final online order for this year 8) on various induction capacitor value from ebay.Theoretically by getting dedicated LOW ESR induction capacitor which would  help to boost output.Unproven at this moment. :D
NickZ
  @magpwr:
   You might also try to use thinner solid core wire for the primary, and even thinner gauge wire for your secondary.
  Old CRT monitors use ferrite yokes, as well, which is where mine come from.
  The smaller the yoke, the more turns you'll need to reach the same output as a bigger one.
  I could not hear your circuit go into a "ringing mode" in your video.
Akula could not make is circuit work when using the first smaller yoke core, which was around 2.5 inch.
  I have one yoke core that was used for the "Joule Ringer" circuit, and it has about 300 turns of 28 gauge mag wire on it.  Thick secondary wire may not be needed for your core to work. Also try different caps, and combining several of them, as well as different chokes.
  I would also try to light a 100 watt bulb at first, or even a 60 watt. The 60 watters seam to work the best for me. I can also light (dimly) a 100 watt bulb on only 500mA, 12v.
  Any way, good luck with your tests.
magpwr
Quote from: NickZ on December 04, 2013, 11:12:44 AM
  @magpwr:
hi Nickz,
I had a another breakthrough last night after posting the video.This should be the ver 4.0 video. :D
The 220volt 1KW Halogen bulb lit up much brighter upon bypassing the (+) choke (47uH ...200uH as seen in attachment) with croc wire  and still keeping the 4 turns on toroid at output to Halogen bulb to limit current.
I'd believe anyone trying out with 110volt 1KW Halogen bulb should have even better result than the above.
The only downside is that the power consumption increased from 40watt back to 56watt(around 5Amp for 7.2AH 12volt battery) for much better output.
GeoFusion
Hi Guyz :)
magpwr:
Great news man :D!
Nice attempt man :), yeah I really think you should try different types of yokes too, Yes 110 1kw bulbs would give better results for sure! I really do think every yoke especially russian ones have something more then just ferrite. :) Give it a try but Great work. Keep it coming!
Yes that Special mode is what i have too :), depends how you connect and reconnect it does it, it Safes and drives  the setting of pulse I see. xP seems you are also guided to figure it out, hope you can figure more out on it man just like everyone els who is trying it out too :).
yes the ringing you could see it too in Akula's devices.
Btw Igor managed to see all the vids I posted recently. he is also getting more ideas , helping eachother out.
check it out :)
http://www.youtube.com/watch?v=XCuhDl-ki0o&feature=c4-overview&list=UUVesA155Der2tRd5vpyYdJw
Grum, and everyone els who wanted to see the Schematic of Igor's TROS system Mod, here it is  ;D
Grumage
Quote from: GeoFusion on December 04, 2013, 02:11:51 PM
Hi Guyz :)
Dear GeoFusion.
Many thanks for posting your schematic this will be a great help to all the constructors here at OU !!
Cheers Grum.
Ps. A number of turns for each coil would also help !!  :)
