0 Members and 576 Guests are viewing this topic.
Grumage
Quote from: verpies on December 08, 2013, 09:45:15 AM
Actually, for kHz frequencies, linear Hall Effect sensors can also be used instead of CSRs.
For a load drawing 10A out of the AC OUT terminals, which at 230V would yield 0-2300W of power transfer, the power dissipated in a 0.1Ω CSR would be 10W.
Note, that the power dissipation in the CSR is independent of the voltage applied to the AC IN terminals, it depends only on the current drawn from the AC OUT terminals, because PCSR=I2RCSR only.
Dear Verpies.
So in layman's terms this circuit should be able to handle up to 3 Kw at 230 V with the correct CSR in place ?? I assume also that it is capable of being used at low voltage DC ?? As this is where most of us here are using.
Cheers Grum.
verpies
Quote from: Grumage on December 08, 2013, 10:09:05 AM
Yes.
It can also have switchable CSRs for other current ranges or a multi-tap CSR.
Yes, however for pure DC, plain voltmeters and ammeters + a calculator would suffice.
Low voltage AC range would require different R3 and R4 and those do not have to be high power resistors.
The same is true for high voltage AC.
As one of the steps in the design, we should calculate a table of recommended R1 values for various current ranges and a table of recommended R3 & R4 values for various voltage ranges
itsu
Quote from: verpies on December 07, 2013, 07:56:14 PM
@Itsu
Please show ARMCORTEX that video illustrating what happens when you try to multiply 2 channels with your scope.
Right, this particulare OWON scope does has a "math" function but its "wave" based only, meaning it only calculates the trace signals
and displays a resulting trace (mostly off screen  :) ), so its kind of poor (understatement), see here:
AC multiplication, watch from the 3 minute mark:
https://www.youtube.com/watch?v=Hvn_WpjiLNQ
DC math manupilation here:
https://www.youtube.com/watch?v=DsMQQFljb2U
What the proper math function of a good scope looks like, see here:
http://www.youtube.com/watch?v=JCibIj_R3HY&feature=youtu.be
This watt meter looks like a usefull project, so i will be ordering an ADL5391 soon.
Thanks,  regards Itsu
Grumage
Quote from: verpies on December 08, 2013, 10:35:58 AM
.Yes.
Dear Verpies.
Not wishing to sound contradictory, but I thought you had said , on many occasions that the use of A/V meters was not suitable for use on the input of pulsed output type oscillators ??
Cheers Grum.
NickZ
   For anyone with a "minimalist" point of view, and a self running device, all these measurement to prove the point to someone else may not be required.
  We are dealing with self running devices, not just another inverter circuit.
  Or like Geo's self running motor/generator powering his house. Just how would you go about measuring that???
  Aren't we getting ahead of ourselves, as no one here has a device that can show even being close to OU, in any form yet. Or able to run itself 24/7.
Even Geo's circuit is just an inverter, efficient, or not so efficient, until he can loop it.
If I'm wrong about this, just let me know.
  When I look at Akulas latest device schematic, I see many similarities to what we are doing here, especially on the main part of his oscillator circuit, which looks very similar to a Mazzili oscillator circuit. The rest of it may just be to control the duty cycle, frequency control, and overheating issues. However his type of coils and how they are wired are possibly the missing link. Again, not one person has been able to replicate even his first much simpler device, and show it self running, even dimly lighting the bulbs, without a battery.
