0 Members and 133 Guests are viewing this topic.
NickZ
  There are many things that can't be proven, yet. That does not mean that they don't exist.
One such "thing" is own own spirit, familiar ghosts, or the unseen multi-dimentional worlds.
  When dealing with non-material aspects of creation, there may be much we don't understand because it is still invisible to us.
  "Dark matter" is one of them. Mind technologies are another.
   However my point is not to convince, or argue.  Hopefully soon we'll have further proof, of those things that we can't see, measure, or understand. Time will tell... as we learn more of what all there is to know.
  Another important point is food production from the Aether. Bypassing the agro stage.
verpies
I am trying to keep the discussion physical.
But I am not discounting the possibility of metaphysical existence, I just don't want to confuse it with the physical.
All of the things that you have written, might have their place in non-physical realm (except for "Dark Matter" and the "Aether filler", which are pseudo-physical concepts).
Physical concepts must be manifestable, falsifiable, ponderable and measurable.
NickZ
  All physical worlds and concepts are created based and caused by metaphysical effects, and so, there is no separating them. Even if you try to. Although to a few people, these metaphysical causes and realms are known and seen by some. Like Tesla, and others.
Or where do you think all his ideas, patents, and designs come from. Out of thin air?
One can not separate or discount the cause of causes, at least I can't.
  Again, I'm not trying to convince anyone, much less the disbeliever. I'm trying to get to the ones that can get it through their heads.  As it's all about field effects, invisible as they may be.
  For those interested in further reading on ideas, experiments, and exploration into Aether field effects:
   http://search.yahoo.com/search?p=aether+field+effects&ei=UTF-8&fr=moz35
magpwr
hi everyone,
I have carried out this simple test today using 300watt 220volt modified sine wave inverter to power 1KW 220volt Halogen tube light using same old 12volt battery.
The primary objective of this experiment is to know if 300watt inverter can light the 1KW tube any brighter than Geofusion roundcore or at least light up 1/3 brightness of 1KW,in theory. ???
Result just came in-Disaster- the 300 watt inverter is unable to handle 1KW load and drainage from battery seems to be fluctuating around 40watt from same old12volt battery.
The 1KW 220volt Halogen tube did not felt even warm at all.
Winner at this moment -Geofusion roundcore.Can someone whom own a 12volt inverter carry out this test as well to double validate be it 110v or 220v.Maybe my inverter is going into error mode and rebooting itself due to overload. :D
There maybe some potential for roundcore project to be part of Akula device without consuming more than 100watt at 12volt battery input.
2nd round of testing for today using 36volts fix power supply 10Amp(bought rather cheaply with free shipment off ebay).
I was curious to know how would 36volts supply fare i were to power 1KW 22volt Halogen Tube.
I have attached the photo which reveal how bright it would be on 36volts.
The current consumption started with 1.6Amp then gradually reduce to 1.53Amp as the tube element gets heated up.Definately little brighter than my current replication attempt.
Power consumption=36voltsx1.53Amp=55watts
Recall the Geofusion roundcore replication where i used 12volts supply ,the power consumption was around 55watt as well but at the expense of higher current draw.
Conclusion-I'm unable to spot any overunity at this moment after carrying out this test which i compared brightness against my Geofusion roundcore replication attempt.
Hoppy
Quote from: magpwr on December 09, 2013, 10:34:36 PM
hi everyone,
Inverters don't like being overloaded and will either cut-out or smoke as you have found out!
