0 Members and 342 Guests are viewing this topic.
d3x0r
Quote from: Farmhand on December 12, 2013, 06:02:11 PM
If 5 Watt zeners are required at the gates of the mosfets on the mazzili circuit to protect them that says a lot of wasted power to me, but what do I know. I try to drive regular mosfets with a 15 volt supply and logic level mosfets I usually use a 10 volt supply. I use an electrolytic capacitor after the regulators. There is a lot to gain by studying the proper ways to drive a mosfet, they become very reliable.
they aren't required... the zener part of this is hardly touched if the voltage divider is tuned for your voltage.
There are 2 significant losses; 1) across the voltage divider, but if using 24V, and 2 10k resistors (20k) is only 1mA or so.
2) the dump to ground when the mosfet is open, and the other side is closed; building a high voltage.  This can be minimized with a diode on the ground to the mosfets.
Otherwise, most power is transferred if you have a load.
Mazzilli Sim ...
Khwartz
Quote from: Hoppy on December 12, 2013, 04:30:28 AM
I agree and the problem is that electronics novices take the video demonstrations from the likes of Geo, Igor and Akula as examples of devices that are operating in some special / exotic mode and/or newly discovered / unconventional manner. These videos are very misleading in that even if the publishers, who in many cases are electronics novices themselves, do not openly claim that their devices are self-running, some viewers assume that they can be developed into self-runnmers with a bit of simple added circuitry, tweaking and tuning. This can soon develop into a form of hero worship, as in the case of the TPU work done by Bruce, free energy generators by Bedini and the various self-running devices claimed by Akula and Kapanadze, to name a few.
The French Youtuber Selfonlypath might appear to be at the front-line of research into the possibility of harnessing zero-point energy if it does exist. However, although I have followed his work, I cannot see where it is leading to. Maybe Verpies can comment and give his opinion on this assuming he has followed Selfonlypath's series of self-triggering videos.
I am all agree with all you have stated, Hoppy.
For my citizen mate Selfonlypath, I think he has a bit lost his original ... path! And we should all encourage him to return to the beginning of his work: the Hector Torres' Transvertor.
Indeed, the idea was to harveness the exceeding energy by a diod-plug, and I don't understand why he is stuck on his sefltriging system if it is he has realized there was no exceeding energy in his said and well demonstrated "anomalus effect", or that he is blinded by his happiness having produced a nice electronic apparatus. But all was at the beginning to make the Transvertor.
BTW, did you follow the work on the Gérard Vialle's "Autogénérateur"? Di Pascali, a Master in Physics, had testified to me having "seen" with his own eyes o.u.
But since a missunderstanding of Verpies about the calorimetric system to check outpower, I have started to realise where we were all wrong, and probably Di Pascalli ("Pascusier" in the French forum "Conspirovniscience"), JNL, all these French too!
Indeed. We were often using a linear resistor at the output to check the intensity by its voltage and have an estminate of the outpower. But would not be a big mistake while it measures a phase shift current in any way? And that phase shift current has no REAL Power in itself? Only if we could convert the REACTIVE part of in a REAL, ACTIVE, Power one?
Could be here lays "The True Question", to honor the memory of a Polish Mathematician I met in Tunisia.
He said that all the problem if to find "the right question to ask", and then the answer comes naturelly.
So here could be it is to realise it could be all about to derive the REACTIVE Power and convert it in ACTIVE one.
Surprisingly, we just go back on Hector Torres diods-plug, and konehead's RomeoUK's Muller dynamo replication schematics (or could be my simplest schematic of possible "pumping effect").
Any way, I have proposed to finance Verpies if he could be agree to produce few of his O/I Power meter, so that experimenters would have just to pay the sending; would mean a standardization of the metering in the o.u. quest and could creat a significant turn for it.
What do you think?
a.king21
Quote from: NickZ on December 12, 2013, 09:03:46 AM
   Although neither Akula nor Geo have claimed anything concerning having a self-runner,  they have been kind enough to show us what they have done, or are still working on up to now, to the best of their abilities.
  None of us here have been able to prove that such devices can be measured in a such way that will prove the point, either. Which may not be as easy as some are making it appear.
  Even if there is no OU to be had, there may still be a way to build a very efficient oscillator circuit that can help to economize on existing power producing sources, such as solar, wind, hydro, or from a normal grid source. This may be the first step in the right direction.
Nick:
Hey man  :-\, it's only to show other possibilities that I have.
don't wrry the RMG will self run, just waiting on my Caps and high amp and voltage rectifiers. otherwise it wont work!.
Btw the 2n3055 circuit, can run on 24 to 36 volts, and gives up to 600 watt energy on 36Vdc. :)
Nick, the Roundcore Experiment, is not all that, it was to see the potential of acoustic resonance. but I did not continue it because it would take alot of time figuring other possibilities out, burining alot of circuits, and yet the output I could not short them because it would put the circuit go in smoke instantly.
selfrunners are not easy sins I have burned alot of circuits befor but I have run some circuits, including the RMG  but cannot handle more then 7 hours.
it's all research and experimentations, if you really want free energy now and self feed and easy, make the motor/gen. :) simple.
GEO DOES CLAIM TO HAVE A SELF RUNNER.
Khwartz
Dry calorimetric test CAN measure true, real, output power.
I believe Verpies W-V convertor can to and even give more very useful data in addition and apparently for only few bugs, and it is not only the output but the imput too apparently for any kind of power supplying.
Yes, any effort is better than no effort. But it is because I am concerned by the energy and time spent since years for near NO real indubitable result, that I support Verpies and Hoppy in their own quest to bring some rigour in the measuremnts in this quest, to save time and energy and go more efficiently towards the purpose.
Khwartz
Quote from: a.king21 on December 12, 2013, 08:11:40 PM
Nick:
If "claimed", not shown yet.
I wish you success for a long sustainable selfrunning you could achieve and share.
