0 Members and 36 Guests are viewing this topic.
DRJOHNBULENTATES
Quote from: Zeitmaschine on September 18, 2012, 03:30:13 PM
First of all the name is dally, secondly he has dismantled his device, so there is a good chance it will never work again, thirdly the whole presentation is suspicious anyway and fourthly he could be a cousin of Kapanadze indeed. :D
I did different
no sparks!  really
no ground
no 2 ground 10 meters ..?.
it is working to use ground MOT
no spark is better result
mant tricks on kapanadzes videos
I saw the real one in Turkey
and I know they are added many parts to just confuse you
it is real simple and works
waith my video soon
dr john Bulent Ates
Turkey
DRJOHNBULENTATES
20 x 150W bulb ( halogen) and 2 heater 1000W each all working well
no ground no spars etc,  bulbs are really full of full bright
MOT uses 220V 3.6 A = 792W..lol
20x150w bulbs  =3000W
plus 2x1000W heater= 2000W
total 5000W
I am sure if I add more they will also work
most of the vido and scheme is wrong
just carefull of winding CW and CCW , it is killing your magnetic field well
no need special parts
only simple wires 2.5 mm 90 turns , 30 turns and  7 tuns final secondary ( 6 mm copper pipe)
you do not need to find ground NO GROUND it works even without spark
I will send new video soon
regards
Dr. John Bulent ATES
HG8AD
NickZ
 Thanks for your comments.
  I think that I have come close to replicating Geo's 300 watt round core test, as he is showing in the following video: http://www.youtube.com/watch?v=Tfia-OK6tIU
  You will notice (Hoppy), that at minute 0.35 the the addition of more bulbs will drop the lumins of the previous bulb(s). As well as the TOTAL lumin emitted from the whole lot of bulbs.
This is the same as what I'm seeing. Although the first 100 watt bulb is lit to about 1/2 grid brightness, any more bulbs added will not provide for additional lumin output, as the small possibly 50 watt output (or so), is shared between all the bulbs.
  I'll be making Geo's RMG replication, next.
  Edit:  I've charged the 12v, 4.5 aH battery and am making another light duration test now, to see how long the 100 watt bulb will light off of this battery/oscillator circuit.
  Here is a pic showing the comparison in brightness or lumin test between a grid powered 100 watt bulb, (upper left corner), and the 100 watt bulb that is below it, which is the one running on the Mazilli circuit. Of course the camera is dulling the actual brightness.
  This circuit is running absolutely silent, no ringing, at least not heard by me. When running on three bulbs, a very slight ringing is heard, very slight, though.
It will not light more than three bulbs (not even dimly).  At least not yet.
  I've just added a pc fan to help keep the fets happy, as I don't want to see more of them go up in smoke. Although the circuit does heat up after a while all the components, and heat-sinks are still touchable, without one fingers getting burned. But, with the fan on, the whole circuit is stone cold.
51 minute run time,  already much lower brightness seen on the bulb, and it's just about to go out in about 5 minutes more or so, as it's already very dim. So total run time is less that one hour, and useable light for about 35 minutes.
  I hope this helps...  No magic here... but still the brightest light I've had in any incandescent bulb circuit, so far.
DRJOHNBULENTATES
Quote from: HG8AD on December 15, 2013, 05:48:23 PM
You saw this already the moto / gen....   http://www.mes50hz.ru/video.php
it is really good for small farms
how can we buy it, what is the price for MES50Hz do you know?
