0 Members and 50 Guests are viewing this topic.
magpwr
Quote from: T-1000 on December 19, 2013, 03:32:15 PM
The circuit you posted kills BEMF. And we are looking for opposite - to maximize BEMF in resonant ringing. You need diodes in series before primary coils for that.
Cheers!
hi T-1000 and  everyone,
Glad to hear from you.We rarely get to see your ou project video these days or you must be on to something.
The objective for me to start playing with Geofusion core is to know how much "power" can the available 14"inch TV yoke core put out or handle.
This project do have some relationship with Akula device the one which uses the yoke core in the earlier version.
Latest update-I have received handful of induction capacitors 0.33uf,0.3uf and 5uf.Some rated at 275a/c some at 630a/c.
I have used 0.33uf induction capacitors instead of existing 0.38uf caps as shown in video on existing Mazilli circuit to power 1KW 220volts tube.I found that light output is the same and the power consumption is the same at 75watt.
Interesting thing to note the circuit took slightly longer to start ringing.I think the delay is  around 3.5seconds.
It's a nice soft start where power consumption start gradually from 20watt,24w,30w,then hit around 90watt in split second then back to 75watt.This is good for the on/off switch. :D :D :D
Conclusion -It's pointless to get induction caps for Mazilli circuit.Please don't waste money.
:D
This is the next stage of my experiment is heading by using PLL I/C-
I have just received the mosfet driver base on attachment IR2111 which i will be combining with PLL OSC I/C:4046.
I will need to find out the frequency which my yoke core is ringing at.Then apply that resonant frequency for PLL I/C:4046.
For the sensing part i may use matching capacitors base on my video on SAME i/c: PLL base Dave Lawton HHO generator.
Objective to achieve resonance even at " under loading condition" in order to achieve ou maybe.
The core for the Akula device is still a mystery to me if someone can assist it would be highly appreciated.
Since Geofusion is using different materials for the core.
HG8AD
T-1000
Quote from: HG8AD on December 21, 2013, 12:06:10 PM
Motor generator Nr:2    ...  http://www.youtube.com/watch?v=7qa3MmdqdQ0
The motor-generator concept can be done quite easily using Archimedes lever principle. Using 3000RPM motor over reductor down to 100RPM for wind turbine generator the spin moment force increases a lot which is enough to power up generator of much higher power rating.
Grumage
Motor generator Nr:1.. http://www.youtube.com/watch?v=zTM_EQim5JE
                            Nr:2.. http://www.youtube.com/watch?v=7qa3MmdqdQ0
Dear HG8AD and all.
Nice demo BUT did anyone notice that the workshop lights brightened as he turned off the power to the device ??
Was it me ??
Cheers Grum.
infringer
Yes it could easily be a fake... But we must assume that it is possibly real and working....
It is entirely possible that the wire is wired and is hoked through the main running up a piece of the square tubing and once the switch is flipped on this hidden and the switch is actually just enabling the other main voltage wire hidden within the leg of course wired in parallel as the other user stated...
You can go down there and see it but can you disassemble the switch and follow the wiring from the switch this is the real question finally put it on something that is capable of moving far from the point of origin this would prove this as working and have the black suits knocking at your door for sure with checks in hand!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
