0 Members and 152 Guests are viewing this topic.
Zeitmaschine
What happens without the ground wire?
Apropos ideas: I'm still wondering, if a coaxial cable (asymmetrical capacitor) can provide additional energy, then what would be the best method to link that energy flow to a (50Hz) output circuit?
Quote from: cosmoLV on March 08, 2012, 09:12:42 PM
Second is bifilar coil closed looped by itself
Can we consider a coaxial cable as bifilar?
And yes it is bifilar coil but in not standard way!
when impulses are generated to inductor it magnetises a bifilar coil (it creates a magnetic field in bifilar coil) so in total you have one source "generating pulses" but in fact you have resonant magnetic generator with two fields
In order to understand the arrangement: Has anyone tried yet a (50Hz) resonant LC circuit wherein the coil L is wound with a coaxial cable (coaxial capacitor), so the shielding is the resonant coil L and the inner conductor is connected to a pulse generator e.g. a high voltage transformer or a nano pulser and those pulses are synchronized (in resonance) with the frequency of that LC circuit?
Grumage
Dear Zeitmaschine.
The earth ground really enhances the effect !! Without it just a bare glimmer. With the ground connected the spark becomes much louder and the lamp brighter.
Cheers Grum.
NickZ
  Latest video from Igor Moroz:
  http://www.youtube.com/watch?v=fn-PcdXIrRA
  Notice that his version of the Mazilli/Royer circuit is different than either of the original circuits.
  I guess that Igor didn't get his induction cooker board fixed.
  Nor do I seen an attempt at a feed back path, yet.
   If Geo can PM me and let me know what he did to "manage" to have his build self-run, I'd appreciate it.
                         NickZ
Khwartz
Quote from: Grumage on January 04, 2014, 04:04:24 PM
Dear Zeitmaschine.
Cheers Grum.
Dear grumage and all.
If been grounded increases the power ouput while been feed by a battery (means no loop possible with the hot wire system of the grid, this real means something,  i.m.h.o. . It would DEMONSTRATE (!) the real possibility to pump electricity from the ground, like exceeding electrons with a ventri like effet.
What do you think?
itsu
OK, finaly i got my new bunch of 47N60C3 MOSFETs, so i tried again my GeoFusion roundcore circuit.
But when limiting my PS current to 3A or so, it still keeps on blowing these MOSFETs in my Mazilla circuit.
So its not the (over)load that is killing them.
Finally i could capture on the scope what is doing that, see picture.
The both traces are the gate signals which should be protected by the 12V zeners, but as you can see with a cap of 5.6nF installed it starts to oscillate causing this 44.2V pp 1.6MHz signal on the both gates, killing the MOSFETs after 2 seconds.
The zeners are not able to protect the gates at this frequency.
The IRFP260N MOSFETs in the exact same circuit do not oscillate, so it must be some MOSFET specific capacitance that is causing the 47N60C3 MOSFETs to be destroyed.
Any suggestions on how to protect the gates?
A 0.1uF ceramic cap across the zeners (= 0.9 Ohm reactance)?
Replace the 470 Ohm resistors with inductionfree/poor ones?
something else?
Thanks,  regards Itsu
