0 Members and 153 Guests are viewing this topic.
Khwartz
Quote from: Grumage on January 05, 2014, 12:43:57 PM
Dear itsu.
I can see what you are writing about so please see amended schematic below !!  :)
My "Capacitive coupling ??" was that loosely looped length of 3 core flex with the 13A plugtop on the end !! We tried various lengths of wire with varied results. I have not been able to try some Coax however !!
And thanks for the advice with regard to the clip leads. Been zapped several times already !!  :)  Not a good idea for someone who has survived 2 heart attacks !!  ;D But I think electricity runs through my veins anyway !!  :)
Cheers Grum.
Hi dear Grum.
On your draw you wrote that you have no connection with mainpower earth system but anywhere you place a conductive rod into earth ground, even far in your garden, I just notice to you that you are always couple with the main grid powering system as earth equal neutral because of the flyback grid permanent connection of neutral to earth ground to economise a wire.
Khwartz
Quote from: Zeitmaschine on January 06, 2014, 06:30:26 AM
Some more theories:
Conversion of the Vacuum-energy of Electromagnetic Zero-point Oscillations into Classical Mechanical Energy
»Our model finally goes back to the year 1935, when Heisenberg and Euler [Hei 36] performed quantum theoretical calculations of the Lagrangeian of photons in electric and magnetic fields, coming to the conclusion that photons propagate in such fields with lower speed than in the vacuum without field. The reasons are found in vacuum polarisation, which influences the Lagrangeian as calculated by Heisenberg and Euler.«
»If electromagnetic waves (such as photons) undergo retarded propagation within electric and magnetic fields (in comparison with field free vacuum), zero point oscillations should undergo the same retardation of propagation, because they have the same nature (to be electromagnetic waves). This means that electric and magnetic fields have an influence on the wave vectors and on the frequencies of the zero point oscillations. This causes an influence on the energy eigen-values of the zero point oscillations.«
According to this, an electric DC-field (no current) can slow down the propagation speed of zero point oscillations. Hence if we create an electric field inside of a coaxial cable (by connecting high voltage to its inner conductor) then inside of the shielding of that cable the zero point waves are slowed down, resulting in a shorter wave length, which means a higher energy density inside than outside of the shielding. If we pulse that DC-field then this should result in an alternating zero point wave propagation speed inside the cable. With the words of Kapanadze: It shakes the aether.
Freie Energie (Raumenergie) - Der Nachweis - Prof. Dr. Claus Turtur
Thanks for sharing, dear Zeitmaschine, looks peticularely interesting :)
Khwartz
Quote from: Dave45 on January 06, 2014, 09:09:26 AM
I wonder if the coax was wound with magnet wire
Is the braided sleeve able to carry a current, it may not because of the crisscross pattern, like a faraday cage.
A couple of years ago I did wind some coax into a coil but didnt get a magnetic field so I didnt work with it anymore, but I never thought to run high voltage through it to excite the ambient.
Dear Dave45, in this case the energetical pumping effect would be just between the inner conductor and its shielding, it does not care of the outside aera of the coax (in this theory).
NickZ
  Guys:
   I just got another PM from Geo. He mentioned that he will continue on now, as his GF went back to her country, so more time to share some more info with us, again.
He has also been in contact with Igor, as well...
  I just wanted to show you all this quote from a previous PM from Geo:
"RMG was self running 2 weeks ago, but did some minor changes and blew my rectifier."
   That's the part that I'm most interested in pursuing, the feed back path.
   Today I was able to light 5 incandescent bulbs with my Mazilli/yoke crt.  460 watts worth of bulbs, (no, not fully lit), but nice in any case, especially for only using an old  very worn out discarded 12v, 4.5ah battery.
  I'm still tuning and experimenting on it, but I just wanted you to show you what I've managed with my circuit, so far.
  I still don't have any protection zener diodes, or enough of the right value tuning caps, for better resonance, and so I can't use higher voltages, yet.
  Any way, here is a picture... more to come, soon.
magpwr
Quote from: NickZ on January 07, 2014, 12:11:54 AM
  Guys:
hi Nickz,
It's a job well done.Congrats.
I am more curious about the magnetic beads on the yoke /roundcore.May i ask does it really assist in increasing brightness.Maybe by causing "the weak magnetic poles in beads to flip" and these helps to increase brightness?
