0 Members and 152 Guests are viewing this topic.
Grumage
Quote from: Khwartz on January 06, 2014, 08:09:27 PM
Hi dear Grum.
On your draw you wrote that you have no connection with mainpower earth system but anywhere you place a conductive rod into earth ground, even far in your garden, I just notice to you that you are always couple with the main grid powering system as earth equal neutral because of the flyback grid permanent connection of neutral to earth ground to economise a wire.
Dear Khwartz.
I feel you have missed out the fact that the 3 metre length of flex with the 13 A plugtop was not connected to anything grid wise !! Just open to free air. At the start I was looking into whether you could carry a mains voltage across a spark gap. This was prompted by a PM from  aKing21!!  As I started to get set up to apply the 240 volts I just touched the open lead onto the HV and the result is what you see on the video.
Now I have since tried to replicate this event again, to no avail !! I must have had the correct frequency to create a sort of resonance !! I have always said that serendipity plays a big role in what we do !!  :)
Another member of this forum who wishes to remain anonymous suggested the effect might be related to Time Displacement Reflection !! So my little length of cable and the right frequency just had a voltage amplifying effect !!
BTW , I went on to try to get 240 v across the spark gap, NO it wont go !! It is as if the Grid sucks the spark all up !! I wonder if my electronic KWH meter is any the worse for that ??  :)
Cheers Grum.
NickZ
 Yes, the 3 magnetite egg shaped magnets do increase the bulb brightness, as well as changing the running frequency, and can also dampen or control the ringing sound.  Stronger magnets may be even more beneficial, but those are what I have.
   Has any one tried to feed-back the output power to self run their set up yet?
  Isn't that what this is ALL about...
GeoFusion
Hi there guyz  ;D
Back back! 8) Happy New year for all. All the best and for the progress in 2014, this year will be a extraordinary one :).
I've not been on the bench for some weeks, spend most of the time with family and loved ones. but all is well and great.
Nick:
I see you managed to light up 450Watt, nice work. keep it up!
Btw about the RMG, yes the feedback path has to be perfected, and also to reduce heat from circuit. many try outs will happen befor reaching it. it's almost a good device :). try to build the RMG Nick, it will take you some time, but the device has some awesome stuff with it when it works, Remember it has this Electron trap between the Flyback piece and the output coil, is where this is possible for it the output that much.
Grum:
:P I see you are experimenting with Spark Gap Tech? interesting because I also did some time ago, also a bit of Don Smith's coiling and managed to light up some lights with them :), Btw coaxial wiring looks so interesting lately, should be used the build coils, recently discussing with Igor about it and to the part of Kapanadze's coil that also uses Coaxial wires, guesing it also reacts as a capacitive effect to it.
Maybe I will, show some of what I discovered or what I have experimented with.
I have even a normal tesla coil that uses real earth with a Iron pin in ground, Between The ground and the tesla coil's below end wire, I could light up lights :), came to understand how the Spark gap tech works, and almost to understand Kapa's 5Kw device.
Well guyz let's see how far we go and this year we all manage what we want :), Btw If anyone is asking for the Motor/Generator, yes it's working, but I'm modifying it to 10Kw now. more power, need more, just put a bit insanity in mind to the work :P! lol
I will upload when it's done, I had to test many things out and be sure of everything befor posting too. as I am carefull too :), The cabal is in desperate movement, so be careful all.
Cheerz~
Hoppy
Quote from: NickZ on January 07, 2014, 11:59:27 AM
Hi Nick,
I've been trying for a good number of years with all types of oscillators and other devices. I thought I came close on a few occasions but measurement error always caught me out! This is the hard part!!
Sounds like Geo is still working hard at it as well.
Grumage
Dear Nick.
Remember this ??
I have circled in yellow where a possible loop back could be achieved., or at least a reduction in current draw !! BTW you remarked about your DMM not working on amps. I hope it is not too daft a question to ask you, you have checked the fuse inside the meter ??  :)
Cheers Grum.
