0 Members and 152 Guests are viewing this topic.
NickZ
  @ Grum:
   I do remember Igor's diagram that you are showing.
   However, I don't think that power can simply be taken from that point, and fed-back to the input side. Although a second battery can possibly be charged in that way, and later switched with the running battery.
  I think that possibly the best way towards having a self runner, is what Akula showed us on his first device video. Which is a separate feed back coil/filter cap/rectifier, then back to the input of the pure sign wave inverter which would allow the system to self feed itself.
  As far as I know, no one has tried to replicate that Akula feed-back design with any degree of success. Although Geo mentioned that he "managed" to obtain some kind of self running results, but at the expense of the rectifier. Which Akula had also mentioned was overheating, on his first device, when running without an earth ground, or battery,  to help balance the circuit.
  I'm just wary of trying to do it right now, and burning out more my hard to obtain power Fets, zeners, caps, etz...
  I'm still working on improving the output and performance of my version of the Geo/Mazilli yoke core circuit, while hoping that some help will come when I need it, for the feed back path.
     NickZ
Khwartz
Quote from: NickZ on January 07, 2014, 12:11:54 AM
  Guys:
   I just got another PM from Geo. He mentioned that he will continue on now, as his GF went back to her country, so more time to share some more info with us, again.
He has also been in contact with Igor, as well...
  I just wanted to show you all this quote from a previous PM from Geo:
"RMG was self running 2 weeks ago, but did some minor changes and blew my rectifier."
   That's the part that I'm most interested in pursuing, the feed back path.
   Today I was able to light 5 incandescent bulbs with my Mazilli/yoke crt.  460 watts worth of bulbs, (no, not fully lit), but nice in any case, especially for only using an old  very worn out discarded 12v, 4.5ah battery.
  I'm still tuning and experimenting on it, but I just wanted you to show you what I've managed with my circuit, so far.
  I still don't have any protection zener diodes, or enough of the right value tuning caps, for better resonance, and so I can't use higher voltages, yet.
  Any way, here is a picture... more to come, soon.
Dear NickZ, all this looks great,  especially if what Geo PM you is true :)
Please,  don't forget to load 1 indentical light bulb directly from the grid so that we could make ourself the comparison ;)
Thanks for sharing :)
Khwartz
Quote from: Grumage on January 07, 2014, 08:51:38 AM
Dear Khwartz.
I feel you have missed out the fact that the 3 metre length of flex with the 13 A plugtop was not connected to anything grid wise !! Just open to free air. At the start I was looking into whether you could carry a mains voltage across a spark gap. This was prompted by a PM from  aKing21!!  As I started to get set up to apply the 240 volts I just touched the open lead onto the HV and the result is what you see on the video.
Now I have since tried to replicate this event again, to no avail !! I must have had the correct frequency to create a sort of resonance !! I have always said that serendipity plays a big role in what we do !!  :)
Another member of this forum who wishes to remain anonymous suggested the effect might be related to Time Displacement Reflection !! So my little length of cable and the right frequency just had a voltage amplifying effect !!
BTW , I went on to try to get 240 v across the spark gap, NO it wont go !! It is as if the Grid sucks the spark all up !! I wonder if my electronic KWH meter is any the worse for that ??  :)
Cheers Grum.
So Very Nice that you had the wire completly unplug but having the phenomenon, dear Grum :)
Indeed, as per "the Low Of Attraction" we were talking about in the holidays period in that thread, can be only "serendipity"  :D
Cheers.
Khwartz
Quote from: GeoFusion on January 07, 2014, 12:20:22 PM
Hi there guyz  ;D
Back back! 8) Happy New year for all. All the best and for the progress in 2014, this year will be a extraordinary one :).
I've not been on the bench for some weeks, spend most of the time with family and loved ones. but all is well and great.
Nick:
I see you managed to light up 450Watt, nice work. keep it up!
Btw about the RMG, yes the feedback path has to be perfected, and also to reduce heat from circuit. many try outs will happen befor reaching it. it's almost a good device :). try to build the RMG Nick, it will take you some time, but the device has some awesome stuff with it when it works, Remember it has this Electron trap between the Flyback piece and the output coil, is where this is possible for it the output that much.
Grum:
:P I see you are experimenting with Spark Gap Tech? interesting because I also did some time ago, also a bit of Don Smith's coiling and managed to light up some lights with them :), Btw coaxial wiring looks so interesting lately, should be used the build coils, recently discussing with Igor about it and to the part of Kapanadze's coil that also uses Coaxial wires, guesing it also reacts as a capacitive effect to it.
Maybe I will, show some of what I discovered or what I have experimented with.
I have even a normal tesla coil that uses real earth with a Iron pin in ground, Between The ground and the tesla coil's below end wire, I could light up lights :), came to understand how the Spark gap tech works, and almost to understand Kapa's 5Kw device.
Well guyz let's see how far we go and this year we all manage what we want :), Btw If anyone is asking for the Motor/Generator, yes it's working, but I'm modifying it to 10Kw now. more power, need more, just put a bit insanity in mind to the work :P! lol
I will upload when it's done, I had to test many things out and be sure of everything befor posting too. as I am carefull too :), The cabal is in desperate movement, so be careful all.
Cheerz~
Hi Geofusion,  I peticulary worried about the honesty of your work while you leaved without sharing the most important experiments of you: self running and overunity demo WITH correct estimation of in and most most important: output.
Can't wait that you share this, so that caution and dubtful man like me could truly estimate the relevence of investing time and money in the replication, that you can be sure I will do too if you indeed go up to the necessary ways to truly demonstrate o.u. or seflloop.
You have all my wishes to succeed both in fully demonstrating your Mazzily-Royer ctr kind in o.u. and permanent selfrun, and for the motor-generator too. As I have written: I do prefer to be wrong in my worryness of these last weeks about you but that we acheive the purpose of our Quest, cause billions of people on this planet do need it!
Cheers,
Khwartz
Khwartz
Quote from: Hoppy on January 07, 2014, 12:22:14 PM
Hi Nick,
I've been trying for a good number of years with all types of oscillators and other devices. I thought I came cloHTse on a few occasions but measurement error always caught me out! This is the hard part!!
Sounds like Geo is still working hard at it as well.
Hi dear Hoppy.
Did you use in your tries the system which use caps on the 2 leads/wires of the feedback of the loop to "electrostatically separate" the 2 sides of the loop?
