0 Members and 150 Guests are viewing this topic.
Hoppy
I also noticed that Geo's RMG schematic shows a Royer oscillator, whilst his post no.2888 shows a Mazillii oscillator was used for the RMG. This is probably just an error on the schematic and a Mazillii oscillator was in fact used. Please confirm Geo.
a.king21
Take a look at this: We've another smart ass who recons he's figured Kapanadze out (Like Tito) and he gives hints but no device.
Maybe putting the 2 together we can figure it out.
http://www.energyscienceforum.com/showthread.php?t=960&page=12&p=12133#post12133
Hoppy
Quote from: a.king21 on January 11, 2014, 06:53:27 AM
Take a very close look at the 'green box' video 4 between time stamps 09:11 & 09:48 for a good clue as to how Kapanadze did it. In particular watch the women as the bearded guy walks away towards the house with the 'kit' and look very closely at his left shoe.
A reminder clip posted by wattsup two years ago in post 15328
verpies
Quote from: xhacks on January 09, 2014, 10:52:58 AM
Look here:
http://www.youtube.com/watch?v=UcwXMq3bUZI
A circumferential layout of multiple phase-shifted windings will not create a rotating magnetic field.
Only a radial layout will create a rotating magnetic field.   See here.
NickZ
  Hoppy:
   Yes, Geo is using a Mazilli crt with the IRFP250N and 260, without the zeners, although still is using some diodes in their place, which he says that also help to keep the heat down.  He did upload the Mazilli diagram (also) as being the way to go on this.
  The coil windings are fairly clearly marked on his diagram. The bifilar coil wound on the pipe (first) in two 100 turn layers, and the 80 turn output coil centered on top of the bifilar, with the third tuning coil and tuning caps on top the output coil. The video also shows how and where these ferrite pieces are placed. His crt is running on 24v. and is almost as bright as grid source. Although I don't see that kind of brightness in the video.
What is not mentioned is the size of the pvc pipe former, which I would guess is about 3/4" to 1" pvc pipe.  The pieces of ferrite are like the one that he is holding in his hand (in the video) from a flyback core about 3/4 inch long, with about 1/2 inch or so inch spacings between them. He says that the spacing is also important to maximize the output.
  I didn't use solid wire, as I can't find that either, and my circuit still works ok, when using it on the yoke core.
  Igors Royer/Mazilli circuit oscillator is a bit different. He is using the white ceramic resistors (wire wound), possibly about 0.5 ohm (maybe 3 to 5 watt), instead. And just a single LC cap, no zeners, but, does use the bigger diodes, and a 4 diode full bridge rectifier circuit.
  I overheated my 1 watt 470 ohm resistors when connecting them to 24v, which burnt my smaller IRF510 fets, and small 12v zeners. It may be best to use white ceramic resistors even if they may affect the crt inductance.
  Using the RIGHT right value tuning caps for this purpose is also a very important part to maximize the output, and also to possibly help to keep the heating of the choke, fets, and resistors down to useable levels. They may be of different values, depending on the circuit for best resonance, and output gain.
  I also use the magnetite magnets on top my yoke core, which do help quite a bit, as far as to tune the frequency, and adjust the ringing noise to bearable levels.
   Here is Geo's first RMG video (below), again, in case some of us missed it before.
   He is going to show some input/output readings soon as well, now that he has a new meter, which can read amps. At least we hope so...
  Geo's RMG video part 1:
  http://www.youtube.com/watch?v=ocrAX7aBHpc
