0 Members and 140 Guests are viewing this topic.
Hoppy
Quote from: NickZ on January 11, 2014, 11:02:46 AM
  Hoppy:
   Here is Geo's first RMG video (below).
   He is going to show some input/output readings soon as well, now that he has a new meter, which can read amps. At least we hope so...
   http://www.youtube.com/watch?http://www.youtube.com/watch?v=ocrAX7aBHpcv=ocrAX7aBHpc  Sorry wrong link.
  This is the right one (below) I couldn't remove the one above.
Yes, let's hope so, as this will reveal a lot about the efficiency of his setup.
"His crt is running on 24v. and is almost as bright as grid source".
??? Nowhere near Nick.
NickZ
  Hoppy:
  I made some edits and corrections to my last post.
  I do agree about the bulb brightness being less than grid source lumin levels.
The brightness is somewhat similar to what I'm getting on my Mazilli/yoke set up now, when using just three 100 watt bulbs. But, with just a single 100 watt bulb, it's quite bright.
  Lets not get hung up on the brightness comparison, but focus on the feed-back path, instead.
GeoFusion
Hi Guyz :)
Hoppy:
Alright, Yes I know ppl been asking for the dimension of the pvc. I've been using PVC of 2.5cm Diameter , thinking 3cm one would do too. :)
The wire gauges might be bit different, but try to Improvise, Try to experiment too. Just as how I did.
Btw about the brightness comparisons and all that, leave it aside for now. as it is irrelevant for me now.
But I will say the lights are Fairly bright at night and they help ;). Be happy what you have is the best thing.
Yes it's best to get the most output out of it, Brightness will increase while Stepping it up. But the main focus is really to feed the system back :). Don't wrry, you can measure this one with Meters, but only one thing, to not get near the Tesla Transformer. It's not the same as how a Spark gap Generator works, where meters get influenced by the fields, . tried it already. It's different.
that is why i used Clamp meter,some others and made comparison with other grid devices with the clamp meter to see if I'm not fooled by the measurements on the RMG.
Be patient, Otherwise try to Experiment with these examples I gave, don't be radical against just like that, it wont help friend. I told many times in the forum, everyone who is willing should try to replicate and experiment with it, sins it has alot of potential. I really need ppl around that do and not just talk. If you know what I am trying to say :-\
Nick:
Yes Mazilli/Royer circuit is used on the RMG see the pic below, that one is used. With zeners, Zeners are needed. But I have tried various ways with other Diodes that can replace them and work well.
But there is something that needs to be carefully studied when the system works, at the input and output.
That will be shown in a vid soon. ;)
Hoppy
Quote from: GeoFusion on January 11, 2014, 01:20:18 PM
Hi Guyz :)
Hoppy:
But I will say the lights are Fairly bright at night and they help ;) . Be happy what you have is the best thing.
Yes it's best to get the most output out of it, Brightness will increase while Stepping it up. But the main focus is really to feed the system back :) . Don't wrry, you can measure this one with Meters, it's not the same as how a Spark gap Generator works, where meters get influenced. tried it already. It's different.
Nick:
Thanks for the additional info requested. There are still a couple of points that require clarification: -
You state on your schematic that solid wire, not stranded should be used where shown to avoid smoked / carbonised mosfets. This makes no sense to me. Please elaborate.
Why do your connections appear not to be soldered  /properly terminated to the copper strips. Is this deliberate and if so why?
If you wish people to replicate your setup, then its important to establish an agreed measuring regime. Brightness of bulbs and expressions such as 'massive output' are meaningless without measurements. Show us a measuring regime and results for your RMG and perhaps then a few competent builders will have a go at replicating against some performance benchmarks. With respect, as 'special' as you setup might be, it will not motivate me to replicate without seeing a more scientific approach to your demonstrations and that must include appropriate measurement and ideally waveform displays (I'm assuming that you have an O- scope). This will enable one to determine if there appears to be anything 'special' that warrants time spent on replication. As I have said before, at present I see nothing special from just viewing your videos.
forest
Hmm Geo and where do you have ground connection ?  ;)
