0 Members and 120 Guests are viewing this topic.
GeoFusion
Hoppy :
I have used the Stranded wire where the circuit is, because while putting solids, It will blow the circuit up while connecting them to the batteries. Might be that stranded has a resistance that protects the circuit. Again try it. I have done my part to see that it happend to me :).
Why are my connections not properly soldered, Some are and some are not. Sins I replace certain points of the Device with other test Substitutes to see how they function. it's all experimental , it's not a finished product. Only when it's Finished and well working device, only then. But Some point are needed to be soldered because of the stress some parts carry.
I Have no problems with your opinions and how you see things Hoppy, :). It's only if you are willing.
But Soon enough I will show some more ;).
Again I can't do any scope shots, I don't have the Equips for it. It's all happening in mind :) and the necessary guidance and help.
Forest:
No Ground connections while it works, It's all ferrite Magnetic Transmutation, Caps , coils, and Special way with split Transformers of certain Ferrite.
But will need maybe someday to Identify the Neutral or minus for everything on the circuit maybe. maybe not
Khwartz
Quote from: NickZ on January 10, 2014, 10:32:31 AM
  @khwartz:
   Have you even tried to replicate what Geo has shown, and see if YOU can show some scope shots, meter readings, and overunity effects, of YOUR replication?
   Geo has already clearly demonstrated what he knows, given us the diagrams, several videos, etz...  What more do you want? A guarantee???  That is ALL he knows, and mentioned that his devices need more attention to be a self-runner, which he is hoping that we will work with him on.
   Khwartz, it costs less than $20 for all the components to make a replication, if this is too much for you to risk your valuable time and money on then.... maybe you should do something else.
You have your opinion and I have mine. I already spend far more time I would be supposed to do for this kind of activity presently. And no, not for me, Geo has NOT YET IN ANY WAY demonstrated what he claimed and I won't replicate a device that not having shown true valuable measurements of o.u. or Selfrunning. This is MY choice and you have yours, so that's the freedom of each of us. I am not forbide you to replicate nor you have to oblige me to do so; and if you are not able to understand that one can contribute an other way than yours, it is your problem, not mine. (I won't discuss this any longer any way). (And if you had well read me before you would know I don't like electronics, so before I replicate a Mazilli/Royer circuit,  I can garanty you it will need have be well proven o.u.; but for the motor-generator, it us an other story because it good amps and voltage, good big parts and high power, very convenient for the electrician I am, I will replicate as promised if enough data.) BTW, if you don't like my post just pass them away! :( And me I will no more care about what you do, as I am sure you don't mind any way)
Hoppy
Geo,
A better way to deal with the overheating mosfet problem, would be to increase the inductance of your choke(s) by increasing turns. As I have said to Nick, getting the zener clamps right is very important in this respect when working with supply voltages in excess of the max gate voltages for the mosfets. I would like to get an idea of the current draw on your RMG with a 24V supply. Have you got a 0.1R power resistor that you could use as a 'shunt' in series with the battery supply wire to measure current by measuring the voltage across the resistor? I suspect that your oscillator is running at below 10Khz, so a DVM should give a reasonable indication of voltage and at least provide a benchmark for others who decide to build your setup.
I find it interesting that you are using copper strips as heat sinks and yet encourage heat spots by using poorly terminated wires in oxidised holes in the strips!
Khwartz
Quote from: Hoppy on January 11, 2014, 02:02:34 PM
Thanks for the additional info requested. There are still a couple of points that require clarification: -
You state on your schematic that solid wire, not stranded should be used where shown to avoid smoked / carbonised mosfets. This makes no sense to me. Please elaborate.
Why do your connections appear not to be soldered  /properly terminated to the copper strips. Is this deliberate and if so why?
If you wish people to replicate your setup, then its important to establish an agreed measuring regime. Brightness of bulbs and expressions such as 'massive output' are meaningless without measurements. Show us a measuring regime and results for your RMG and perhaps then a few competent builders will have a go at replicating against some performance benchmarks. With respect, as 'special' as you setup might be, it will not motivate me to replicate without seeing a more scientific approach to your demonstrations and that must include appropriate measurement and ideally waveform displays (I'm assuming that you have an O- scope). This will enable one to determine if there appears to be anything 'special' that warrants time spent on replication. As I have said before, at present I see nothing special from just viewing your videos.
I would not have said better! Dear Hoppy :)
As I know we share similar "needs" before to go on on replication (you probably know that, basically, in the professional world, "a replication" is a checking made to verify  if a system given as already working was indeed working - not false reading - and that is not an accident?
It is this methode which allow us to use near anything we touch and use today from the industry, including the computer or mobile you use to communicate, isn't it? ),
So here a link towards a thread in a French free energy quest community with trully serious hope of EM/EM o.u., in fact, if the calculations are correct, we already have it! See by yourself and if you need translation,  just ask me :)
http://www.conspirovniscience.com/forum/index.php?showtopic=941&st=480
Cheers.
