0 Members and 193 Guests are viewing this topic.
Khwartz
Quote from: NickZ on January 17, 2014, 10:30:56 PM
  Ok, guys:
  Here's a pic of what I got done today. It's not much, although it took a while.
  RMG air coil was partially built up using 10 turns of thick (unknown gauge wire) for the primary, a 70 turns (red, thinner wire) output coil, and and a white 27 turn (resonant coil, or feed-back coil).
Dear NickZ, looks to me a nice thing having multiple colour for wires like you did (don't know i if it was on purpose) cause it very helps to understand the viewer of the pics to understand what is going on; Thanks for the idea :)
Khwartz
Quote from: Hoppy on January 18, 2014, 12:56:45 PM
Nick,
I tried the transformer earlier and I get a nice 110V across the lamp and trafo input and around 55V open circuit on the trafo output (step-down). However, when rectified, smoothed and connected across the battery, the input current actually rises a few hundredth's of an amp and the voltage across the smoothing cap drops to zero. The transformer is being shunted by the much lower resistance of the lamp, so very little current is being drawn by the transformer and its battery load. I've tried this with several FE type setups in the past and its clearly not a way forward to improved system efficiency let alone self-running!
I have to clear my bench for a work project next week but will keep the replication intact and return to it if Geo comes up with a loop back solution.
Dear Hoppy, what about in a first time to just "off" the light bulb so that the transfo will no more be shunted by (but with the necessary tuning) and see what is going on with the current drawn in the circuit and the voltage, to check if any exponential phenomenon?
magpwr
Quote from: NickZ on January 18, 2014, 05:33:52 PM
  Ok, thanks Hoppy. I understand...
  Well, I reversed the flyback secondary, but it didn't make a whole lot of difference.
  Adding a couple of tuning caps to the air core, and some flyback ferrite pieces to the inside the pvc pipe, did not give me amazing results, either. But, the bulb will hardly light without the single piece of ferrite, which is what makes it work best. Adding more ferrite pieces only decreases the output.
  My meter is connected at the bulb, and it is tapped to the right, which is on the 1000v AC setting. If that is to be trusted (I doubt it).
  The 25 watt bulb is barely lit, (about 20%, or so), 100w bulbs will not light. Adding more ferrite to the pipe does not improve performance. Just a single piece is working best, for now.
  I'll continue tuning, after a couple more beers...  May not help, but doesn't hurt either.
  Here's a pic, any suggestions are welcome.
Hi Nickz,
I do know using fix capacitor to achieve L/C resonance is a way more challenging than using a movable ferrite rod/pieces within core.
My suggestion-
Do try to put ferrite pieces in a pvc pipe or ferrite rod then slowly move in or out.Great deal of patience is needed similar to tuning a crystal radio but in this case a light bulb.
Recall the old posting somewhere last year related to a experimenter in China-Don Smith replication.CW & CCW was used with capacitor.The inner pvc pipe was to be be moved in or out manually to achieve
resonance.
I have attached an image to help to you recall.Please use that video as a rough guide for the connections.The circuit diagram drawn in site seems to be inaccurate,likely the video demo is the latest.
I have also attached the site related to building guide along with video after short advertisement.Please use google to translate site chinese to english.
http://user.qzone.qq.com/278885050/blog/1378191565#!app=2&via=QZ.HashRefresh&pos=1378191565
This is the most informative video related to achieving resonance between CW /CCW coil -
Please do watch this video which i have easily replicated such that the oscilloscope would show a rising waveform.Please play around with expanding or contracting both CW/CCW coil with similar matching capacitor such that both CW/CCW L/C resonance is the same.Before carrying out the experiment shown in youtube link.
I was using 2n2 50KV caps for the spark gap with flyback transformer.Please do set  probe to 10x range which is connected to receiving coil as shown in video.
http://www.youtube.com/watch?v=D7QiI8p1gi4
NickZ
 The Don Smith type device replication on the Chinese video has been shown, seen and refered to several times now. I just made a reference to it, a couple of post ago.
  I have been tuning the air core using ferrite pieces, moving them around inside the core.  As well as tuning using different value caps, etz.
Have you been following my posts? No?
  Do you have a working GeoFusion RMG device replication? As that is what is being worked on here, at this time.
havuhung
Hi All,
I have some questions with diagrams and device of Chinese friend this test: It refers to the device's OU not?
