0 Members and 415 Guests are viewing this topic.
Hoppy
Quote from: Khwartz on January 19, 2014, 05:44:41 AM
Dear Hoppy, what about in a first time to just "off" the light bulb so that the transfo will no more be shunted by (but with the necessary tuning) and see what is going on with the current drawn in the circuit and the voltage, to check if any exponential phenomenon?
No phenomenon here Khwartz.
a.king21
magpwr
Quote from: NickZ on January 19, 2014, 09:15:27 AM
The Don Smith type device replication on the Chinese video has been shown, seen and refered to several times now. I just made a reference to it, a couple of post ago.
  I have been tuning the air core using ferrite pieces, moving them around inside the core.  As well as tuning using different value caps, etz.
Have you been following my posts? No?
  Do you have a working GeoFusion RMG device replication? As that is what is being worked on here, at this time.
Hi Nickz,
Please do accept my apologies. :D
I definately  did miss couple of important posting and  merely recalled those that i find interesting which a copy of image or links was saved locally.
I only became interested in this topic after Grumage did some video presentation somewhere around July or Aug 2013.
Related to Geofusion RMG device-
Recently i was experimenting with 3 inch toroid(Green colored,Iron powder toroid) instead of Yoke core ,combining with Mazilli oscillator with my usual 600v mosfet(IPW65R037C6).
Using 3inch toroid the max power drainage from battery was 70watt with 1KW halogen load for around 10 seconds after which the power hit around 320watt which i had to quickly disconnect the power to save mosfet.
I then proceed to use PWM circuit with inverted/non-inverted output to 2 mosfets .Before connecting the Halogen bulb.I tune the frequency on PWM circuit(using below 50% duty cycle) until i achieve maximum voltage output from toroid for the lowest power drawn around 1.8watt using 12volt battery at around 70volts output for 37 turns at secondary and 6-0-6 for the primary.
Choke is not needed at positive supply for pwm based oscillator.
Using pwm circuit the maximum brightness\power achieved was around 130watt(using watt meter) for a few seconds before i destroyed one of my 600volt mosfet (IPW65R037C6).
The root cause-I used a smaller heatsink compared to the ones i used in my youtube video Roundcore replication attempt 1.0. .. 5.0
I am having big problems finding a decent large size heatsink locally.The price for large heatsink found in internet is insane around $60...$80 each for a piece of aluminum metal.
Because of this heatsink issue if you noticed carefully all my recent video presentation are all kept short within 2minutes. ???
To Geofusion  -I am staying in an island as well(Singapore 50km wide and surrounded by sea.Pirates still exist even in this century in nearby countries) ;D . ;D ;D
Can anyone recommend me a site to purchase decent large heatsink cheaply.
forest
Quote from: magpwr on January 19, 2014, 12:15:38 PM
Hi Nickz,
Look at scrap yard collecting electric/electronic waste. They may sell you dismantled heatsinks fro old electric apparatus. Alternatively old TV set contain an aluminium heatsink but not very pretty looking  ;D
