0 Members and 1547 Guests are viewing this topic.
Farmhand
OK I can't say I understand everything in the patent, but I think I get the jist of what is supposed to take place.
It would seem to me that the Kunel Patent is a descendant of the Coler device Stromerzeurger which I also think is interesting. See attached.
My thinking is that regardless of "over unity" per se as such, or not, if energy can be got from a device over and above the input from us and somehow permanent magnets can be used to achieve that without "draining" the magnets, or without draining them quickly, then the device would still be very useful.
I would like to just concentrate on building some prototypes of these devices, Kunel's device and Coler's (Stromerzeurger). To see if anything happens for me.
Below is just an observation after a quick play around.
I did notice an odd kind of effect when just manipulating two strong Neo magnets and a iron powder core, I will explain, with the north pole of one magnet attached to the top of the core when I approach the other end of the core with the other magnet's north pole I at first feel the core repulse the north pole of the magnet as the core has been made north by the attached magnet, but if I push through the repulsion the magnet suddenly attaches to the core, at about 10 mm distance the two forces swap and the approaching magnet is then attracted to the iron core.
So when I allow the two north poles to attach to each end of the iron core what do we end up with in between the poles in the center of the rod ?
I say it must be a null zone between two north poles  repelling each other but the core piece prevents that repulsion. Still the repulsion between the two magnets must be there but the attraction of the magnets to the iron is stronger so it happens. Not something previously unknown but just worth noting.
Now who is interested in some targeted experimenting in this line ? I am, if no one else wants to build I will likely not start a thread for myself.
I was thinking I might try a simple circuit something like in my sketch. Come to think of it when I look at the drawing maybe the output capacitor could be in series with the supply capacitor rather than connected to circuit ground..
a.king21
  Kunel:I intend to explore the concept and have ordered some iron wire. But I intend to integrate it into the TK device.
magpwr
hi everyone,
I merely conducted a rather simple experiment to demo 1 watt HV to current converter using induction coil.
Do observe the violent orange spark on induction coil base on attached video.
(Please do not replicate this experiment there is no ou or heating of screw driver in induction coil.It just a demo of hv to current)
The power source is a 3.9volts AA Li-ion battery current consumption to HV circuit at 280mA .
The 1watt flyback transformer circuit diagram was already revealed in my previous youtube video http://www.youtube.com/watch?v=BoUivNtYFIA
Please see attached 4.5mb 240p video and image.
This coil design was based on SR193 replication which was a failure for me.
Hoppy
Quote from: NickZ on January 19, 2014, 07:42:09 PM
  Hoppy:  Optimum results is opinion based.
Hi Nick,
OK. Then I consider this photo of a 240V / 1000W halogen strip bulb is tuned to optimum brightness for my Geo replication.
T-1000
Quote from: Hoppy on January 20, 2014, 03:37:07 AM
Hi Nick,
Good to se you got hands dirty for experiment :)
The brightness of bulb depends on magnitude of spikes and capacity of capacitors.
To get even more brightness you can get another leg with same resonant LC circuit and step up voltage even more.
Way to go for efficient lighting and household heating!
