0 Members and 199 Guests are viewing this topic.
Farmhand
Grummage, I notice (if I am seeing it right) in that AWG wire size chart that when we go down the list we can see that once we get to 1.3 mm diameter or so the cross sectional area (figure) becomes less than the diameter, but above that it is more and below it is less.
Cheers
NickZ
  Here are a couple more pics of my RMG replication.
  Although I've replaced the first flyback core this new slightly bigger one (that is not broken), I have not notice any significant difference, or improvement.
  I'm still only able to light a single 25 watt bulb dimly. No other higher wattage bulbs will light, and there does not seam to be any higher output at the ferrite filled air core coils, compare to what just what the flyback will do, by itself.
  I've also tried to tune it with different caps, ferrite pieces in the pvc pipe, etz...
  Any ideas are welcome...
Hoppy
Quote from: NickZ on January 21, 2014, 12:21:30 PM
Try adding more caps after the ferrite trafo. You could also try more caps on the Mazillii to bring the frequency down. You could also try a new pair of transistors.
NickZ
   Hoppy:
   The two Fets are brand new. I also replaced the two 10k resistors, but, perhaps the diodes also need to be replaced, as well. I may change those to the UF series, that allow higher output.
   These are the caps that I have on hand, that I've tried out, along with different flyback ferrite pieces. Both on the oscillator side, as well as on the flyback output side.
  I'll try to get some of the caps that Geo mentioned (0.33 650v poly). But, up to now I have not been able to obtain any of those.
  I'll replace the air core with my yoke to see if the problem is in the air coils, or with the oscillator. If the yoke lights up 500watt worth of bulbs, then I'll have a better idea of what to do about it.
Grumage
Quote from: Farmhand on January 21, 2014, 02:02:43 AM
Cheers
Dear Farmhand.
I see what you mean !! However I got the calculator out and that is the way they are !! Maths was never my strongpoint !!  :)
With regards to your recent post.................http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg383882/#msg383882
Is this the Gary effect ?? Perhaps Verpies could elaborate ??
Now my health is improving I am going to do a few experiments with  the Kunel patent and also look into one of Verpies "Pet's" which I feel is closely connected. Again dear Verpies I have not mentioned this without your permission !!   ;)
Cheers Grum.
