0 Members and 96 Guests are viewing this topic.
a.king21
Quote from: d3x0r on January 22, 2014, 02:58:40 AM
If you would stop ignoring me; I posted the schematicc from it in the next message
I see the Akula, but not the v8carlo version you mentioned.
From other Planet
Quote from: a.king21 on January 22, 2014, 02:52:12 AM
Can you show scematic of v8
carlo's device which you used. Maybe we can analyse it, and see if we can improve it?
I used additional chokes and caps for filtered DC Input/Output, my HV Voltage was around 500 volts, as spark gap i used a 230v surge arrester. Caps are 82nF(KP)/1500uF(electrolytic), diodes UF5408, coil is made of 24 turns 0,75mm² double speaker wire wound on PVC pipe(air core).
Big thanks to carlo for sharing!!  :)
a.king21
From other planet: Thank you for the schematic, but I was hoping for more specific details from D3xor.
d3x0r
Quote from: a.king21 on January 22, 2014, 03:21:11 AM
Sorry I had just woken up and missed 50% of the message context...
NickZ
  Last night, I connected a full wave bridge rectifier and a 400v, 200uf capacitor to the output of my white coil wire feedback coil (white coil wire on the air coil). This feedback path was then connected back to my 12v battery input terminals.
  This was after previously running the circuit and bulb on for 2.5 hours.  The single 25w bulb did dim somewhat when connecting up the feed back circuit, but the bulb continue lighting for another hour or two longer, for a total run time of about 4 hours or so.
I fell asleep and when I woke up the bulb had finally gone off. Total run time was about 3.5 to 4 hours.
   I'm recharging the 12. 4.5aH battery now for another run later on today, or tonight.
   I will also be obtaining a 24v 20 watt (or so) solar panel, to connect up to this circuit.
Hopefully I'll be able to find the 18v zeners, as well.
  Again, any ideas are welcome.
  Geo: Where are you....???  I've repeatedly asked for your help with the feed back circuit.
Anyways, I'm doing what I can on my own. What else can I do...
