0 Members and 58 Guests are viewing this topic.
Hoppy
Can anyone please suggest an alternative or provide the specification for the Russian rectifier / diode K203A?
Hoppy
itsu
Quote from: Hoppy on September 23, 2012, 07:55:33 AM
Hoppy
Hi Hoppy,
user "Сергей Ð'." wrote on 15 sept. in the other thread (TK):
QuoteFor diode use Ð"Ð"РÐ' diodes like КÐ"203А, КÐ"204, 2Ð"210А, 2Ð"210Ð', КÐ"210A, КÐ"210Ð', Ð"Л 132-50. Equivalent diode exist.
Some diodes which can be used:
Ð"рейÑ,,овы диод с резким воссÑ,ановлением запираюшиÑ... свойсÑ,в Ð"Ð"РÐ' - Drift Step Recovery Diodes DSRD
Ð"иод с задержкой лавинного пробоя Ð"ЗЛП  Diode - Avalanche S diodes ASD
КÐ"204А   -> 400Ð'  0.4А
КÐ"226Ð"   -> 800Ð'  1.7А
КÐ"230Ð"   -> 1000Ð' 3.0А
КÐ"220Ð"   -> 1000Ð' 6.0А
дл112-16 -> 1500Ð' 16А
Ð"Л132-50 -> 1500Ð' 50А
Ð'2-320    -> 1200Ð' 320А
Ð"Л123-320 -> 1200Ð' 320А
Ð"133-400  -> 2400 400А
Ð"Ч143-800 -> 1400Ð' 800А
Ð"143-400  -> 2400Ð' 800А
Hope that helps,  regards Itsu
Hoppy
Quote from: itsu on September 23, 2012, 09:06:48 AM
Hi Hoppy,
Thanks Itsu.
Hoppy
d3x0r
was tracking down parts
[size=inherit]KD203A silicon diodes, diffusion. [/font][/size][/font][/color][size=inherit]designed to convert AC voltage at up to 5 kHz. [/size][/font][size=inherit]Available in-metal body with rigid leads. [/size][/font][size=inherit]type diode and circuit connecting the electrodes with the conclusions presented in the case. [/size][/font][size=inherit]Weight diode with accessories is not a '18 [size=inherit]Main technical characteristics of the diode KD203A: [/size][size=inherit]• Uobp max - Maximum Reverse Voltage: 420 V; [/size][size=inherit]Inp • Max - Maximum forward current: 10 A; [/size][size=inherit]• Fs - Operating frequency diode: 1 kHz; [/size][size=inherit]• Unp - DC Forward Voltage: less than 1 V at 10 A Inp ; [/size][size=inherit]• Iobp - Reverse Current: up to 1500 mA at 600 Uobp[/size][/size][/font]
[size=inherit]
[size=inherit]
Type diode
Rectifier
Maximum continuous reverse voltage,
420
Maximum positive (for half-rectified) current, A
10
10
Mounting Method
in the hole
Maximum recovery time, ms
Maximum peak reverse voltage,
600
The maximum allowable direct pulsed current, A
100
Maximum reverse current, uA
1500
Maximum forward voltage, V
1
in Ipr., A
10
Frequency, kHz
1
Overall capacity Sd.pF
Operating temperature, C
-60 ... 125
Housing
kd11
Manufacturer
[/size][/color][/font][/size][/font][/size][/font][/color]
verpies
Quote from: itsu on September 21, 2012, 04:51:08 AM
Thanks Vortex1,  thanks verpies
for your feedback, its much appreciated.
I will have to do some work/learning and try to incorporate your advices.
Regards Itsu.
I would like to see your scopeshots of voltage between the ground and sources of your MOSFETs as well as the voltage on the power supply pins of the TL494 IC (measured from the same ground point).
Ideally the scope should show pure DC.
