0 Members and 225 Guests are viewing this topic.
verpies
Quote from: Farmhand on January 20, 2014, 02:23:46 AM
I did notice an odd kind of effect when just manipulating two strong Neo magnets and a iron powder core, I will explain, with the north pole of one magnet attached to the top of the core when I approach the other end of the core with the other magnet's north pole I at first feel the core repulse the north pole of the magnet as the core has been made north by the attached magnet, but if I push through the repulsion the magnet suddenly attaches to the core, at about 10 mm distance the two forces swap and the approaching magnet is then attracted to the iron core.
The line surrounding the magnet/core combo where the forces "swap" direction is called the "Neutral Zone" and it has been discovered by a guy named Wesley Gary over 100 years ago.  You can read about it here.
A running permanent magnet motor based on this "Gary effect" was witnessed by me at an inventor's convention in 1997, I had inspected it thoroughly with Hall and MR magnetometers and search coils (Yes, I was allowed to disassemble it),  I even moved it to another location of my choice in order to eliminate any deliberate external local magnetic fields and I did not spot any skulduggery.
I was not able to replicate it.
It is the only working device that I could not explain.
verpies
Quote from: Farmhand on January 19, 2014, 10:12:28 PM
I just started to read this patent, and I am interested ! I might like to try this idea. Can't hurt me that is for sure.  :)
The attached Annis Eberly patent is related to the Kunel patent (diversion of main flux by a perpendicular flux)  and IMO it is even better, e.g. it contains scopeshots and even experimental test run results !
penno64
Hi Verpies,
How I would love to hear more regarding the pmm Wesley type motor.
I can only dream of such a machine.
Regards, Penno
NickZ
  quote from Verpies:
"The only reason is the insulation thickness.
Besides this, for transformer windings, a stranded wire is better than solid.
Litz wire is the best for HF applications"
                                                          end quote
  Ok, well, I hope that's true.
  The solid wire as is used in house construction also has plastic insulation, although it may be a bit thinner than the stranded wire insulation. Or the wire itself may be thinner as there is no spaces between the strands.  This I'll have to verify.
  Most solid core wire that is used for transformer use, is magnet wire, without the plastic insulation, just the thin lacquer coating. But, like you say, the stranded wire may work as well for our purpose. Who knows.  I'm just trying to replicate Geo's diagram as close as possibly.
  I sent an e-mail to Igor Mopoz (or Moroz) today, and got a reply back saying that he doesn't know what videos of his that I'm mentioning. I didn't mention any of his videos, just said that I've been watching most all of them religiously. And asked him for advice on a feed back circuit design for my replication of the Geo/Mazilli circuit, of which I send several pictures of.
He didn't know what I was talking about and said:
To Me                Today at 3:44 PM    "Sorry, buddy, I think you're wrong address. I do not understand what video you're talking about."
  Wrong address???  Ok, well, it's the one that he gave out on YouTube,   igor.mopoz@gmail.com   as a reply to a comment on one of his videos.
So, now I don't know what's up with that. Any way, I tried...
  Geo probably knows Igors correct e-mail address, as he's been in touch with him.
But, neither of them seam to want to mention anything about the feed back circuit path.
  Makes me wonder...
  "The Shadow Knows"...  But, he ain't saying...
Farmhand
Quote from: penno64 on January 22, 2014, 11:07:53 PM
Hi Verpies,
Regards, Penno
Hi Penno, I found this page. -
The Gary Effect Magnetic Motor
http://www.centuryinter.net/tjs11/church/gary.htm
Cheers
