0 Members and 142 Guests are viewing this topic.
penno64
Hi Farmhand,
Thanks for that link.
The detail over at rexresearch is also pretty good.
I was simply amazed that Verpies stated that he had viewed a machine that self ran.
Regards, Penno
Farmhand
Well after playing with the magnets and the core piece the other night I got to wondering and thought it had potential. I had never heard of the effect being used before but I did read about a similar effect somewhere so I knew it was known already.
It would seem to me that the Coler and the Kunel and some other possibly valid devices may be based on this effect or the use of it in some way. It is interesting, bringing forth a working device through understanding the processes that enable it is the goal. Then it can be explained. But to understand better maybe we need to experiment more.
I never shy away from something I think may have potential.  :) Boogie men don't scare me. hehehehe. Maybe I'll get lucky and work out a practical device that shows something that can be measured properly. I'm running the grey stuff on a few extra watts, and getting hungry.  :D
Cheers.
verpies
Quote from: penno64 on January 22, 2014, 11:07:53 PM
How I would love to hear more regarding the pmm Wesley type motor.
It was the configuration shown in Fig.2 with the frame cut out of plexiglass.
It did not resume working after I had reassembled it.  Apparently it had to be "tuned" critically.
verpies
NickZ
 Hoppy and All:
  I changed the flyback core and additional ferrite filled air coils back to the yoke core that I had on it previously.
  The results were that I could light 500 watts worth of bulbs (5, 100 watt, 110v bulbs), using the yoke core.
  So, there is nothing wrong with the Mazilli circuit, as it works as it had previously, or  even better now.
  But, the problem is that I'm back to having the heat issue, as the fets get very hot only after a few seconds, and can't be touched after one minute run time. Even when lighting only a 25 watt bulb by itself. If I add a PC fan to the circuit, the fets still overheat, but not as much.
Adding tuning caps did not help to keep the heat down. But, I'm ordering some more tuning caps today, to see IF that will help.
  After looking at Akula's original yoke circuit video, again, I think that I'm getting fairly close similar result. As he had a heat issue, also, and his fets and rectifier were getting too hot to touch, as well. Although he could make the circuit self run, at least for a short while before a possible meltdown might happen.
  So, my main concern is to obtain a working feed back path, as well as to resolve the heat issue on the yoke set up. As the yoke core puts out much more output than the flyback/air coils do.
  Any ideas are welcome.
  P.S.
  Will whoever added an image to the other Kapanadze thread, over the recommended 1200 pixels wide, please remove it and re-size it. Or you'll keep messing up that thread.
  Thanks, in advance.
