0 Members and 288 Guests are viewing this topic.
verpies
Quote from: Grumage on January 30, 2014, 06:15:58 PM
Dear Stefan.
Many thanks for putting OU.Com back to the way we like it. I am sure other members agree !!  :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :)
kindest regards.
Cheers Grum.
I wholeheartedly agree !
NickZ
    Geo:
    Thanks for your comments.
    My current version of the ferrite filled air core has 70 turns, of secondary red coil wire. The thick outer primary coil on the air core, has ten turns. There is another coil (white wire) that is there to inductively tune the output, using the 0.33 caps, which I am still looking for, and waiting for an order. But, as I was getting much more output from the yoke,  compared to the flyback core, I'm using the yoke, again, onto the Mazilli oscillator for now.
   I've also replaced the zener diodes onto the circuit with new ones now, although only the 12v ones, as those are all I can get, so far.
  I'll test this circuit on 24v when I can get the 5 watt zener diodes.
  Right now I'm tuning the crt using just a 10v, 1.4 watt wall adapter, which does not heat anything up, or run down like my batteries do.
   It seams that tuning also requires using the right input source or battery, and having some amps behind it, as well as at least a 500 watt load, on the output.
As it's NOT the same, tuning while using a 25 watt bulb as a load, as with 5  100 watt bulbs, to maximum obtainable lumin levels.  At least it isn't for me, on this device.
GeoFusion
Nick:
Alright man, all cool ;)
it's all about waiting a bit and then applying :).  Here the tv yoke is to be tested on the RMG as I haven't tried it yet , great to see that it also output's good  with the circuit like this, never tried it yet with mines, but thinking it's all when you have more caps is when you will see the differences. the tuning and for output energy :).
Oh alright the white wire is the one to tune the ouput with caps, alright (= that is what I wanted to know. try also bigger values of caps as experiments.
But Keep it going with the TV yoke, It's different  ;D and looks great and might achieve great output with it.
Alright Great :), yeah 12V zenerz will do for now, I have 16V zeners and 18V. but keep trying to find higher Voltage zeners though  for further experimental progress.
niceee only with a 10V 1.4 watt Adapter  ;D, to see it only takes a bit of energy to output that all.
yes the tuning requires the right input source, as I use 12V car batteries and place them in serie for 24 or 36 volts. But the amount of  amps in input are also needed. I will upload a new video with measurements  sins I have meters now, and even to show the frequency it's giving at output and to see if it influences at input.
yes it's like giving abit more input to get more output. But it's again all about the capacitor bank that will make the difference and you will see how to balance it  :) and to see how to achieve greater output lumins too.
a.king21
As promised here's a cool circuit you can build
Gadget has commented on it as follows:
Hi. It's a modification i did to Lasersabers original circuit the crossover . I Added a Diode and cap  and yes 220 volt Led bulb..It's a nice circuit and can pull from the electrostatic / Ground potential if wire is added to your input capacitor/source leads . It's not Pocketpower+ but an interesting Circuit Never the less. Free as you can Snag from air/dirt or earth batteries.. Yes Jesus Aka Nieves Redrew It for Clarity and he Makes great Schematic Pics.i thank Ls for the original posting of the original circuit . I Modified it to create a feedback loop . If you use the right transistors and diodes and the exact bulb it will ring for days on the cap alone and if a battery is inserted it will increase in voltage with any antenna ground setup . I can't tell if its collecting radio waves or ions but the higher you go up the more power you get . It also runs sweet on a carbon rod and a Magnesium rod in dirt . I am waiting for Solar panels and will take orders for Pocketpower+ if anyone still Interested in it after i get them..  Gadget
(http://laserhacker.com/forum/index.php?action=dlattach;topic=63.0;attach=655;image)
NB the 220 pf should read 220 v
NickZ
  a.king:
  If you were to build the cross-over circuit, that Lasersaber came up with, like I did, and add the diode and small cap to that circuit, (Gadget's addition), you will find that it does not put out much power for any amount of time. It will DRAIN the run battery,  as well as also recharge that same run battery to original voltage levels, but not to the same starting amp levels. However, the light output from the bulb is minimal, and not worth the effort.
Or Gadget or Lasersaber would have kept at it and made it into a real self runner.
  Here is a picture of my version of the cross-over circuit:
