0 Members and 1619 Guests are viewing this topic.
a.king21
Thanks for your comment. I have got all the components together but have not got round to building it. What intrigued me about the circuit is that it allows for electrostatic input into the circuit to prolong the lifespan.
My experience with the Benitez experiments is that if you allow electrostatic to mix with ordinary electricity then you get a superconductivity event.
Analyzing Akula's circuit - I have come to the conclusion that he also mixes frequencies. I call this stochastic mixing although that is probably not the correct term.
a.king21
Nickz: Did you use the 2n3055 transistor?
NickZ
  a.king:
  I had used the 2N3055, as well as several other transistors, on this circuit, as well as on the original Joule Ringer circuit, which the cross-over circuit is based, and modified from.
The transistor that I found works best was the TIP3055 from Radio Shack. It's cheap and easy to obtain, as well. Although the battery can get recharged back to starting voltage, by this circuit the mA levels don't do the same. So, a fluffy voltage, with little amps.
This can all be improved, but the light output, or lumin levels from the circuit was not what I was looking for.
  One of Gadgets cross-over version, was said to have burned itself out from over-runing itself, and took off,  but, burned out.   Why he never got it going again,  is my question...
  In any case it's a very interesting circuit, and does have some recharging or self running aspects to it. Just needed further improvements, possibly.
  There are several good videos on YT about the cross-over crt, made by some others, like lynxsteam, to look at. If you haven't done so already.
  We need to find the basis for why any unknown effects are created in circuits like these.  And, this LS/Gadget cross-over circuit may help to better understand some of what may be happening in the self-runners, in general. And just how to achieve a useable feed-back path, one that works.
NickZ
  Guys:
   Here is a picture of my new output coil for my version of the RMG device replication.
   I'm working on the feed back circuit for this device, now.
   Any ideas or help with a feed back path is welcome.
DilJalaay
Quote from: a.king21 on February 02, 2014, 11:05:30 AM
As promised here's a cool circuit you can build
Gadget has commented on it as follows:
Hi. It's a modification i did to Lasersabers original circuit the crossover . I Added a Diode and cap  and yes 220 volt Led bulb..It's a nice circuit and can pull from the electrostatic / Ground potential if wire is added to your input capacitor/source leads . It's not Pocketpower+ but an interesting Circuit Never the less. Free as you can Snag from air/dirt or earth batteries.. Yes Jesus Aka Nieves Redrew It for Clarity and he Makes great Schematic Pics.i thank Ls for the original posting of the original circuit . I Modified it to create a feedback loop . If you use the right transistors and diodes and the exact bulb it will ring for days on the cap alone and if a battery is inserted it will increase in voltage with any antenna ground setup . I can't tell if its collecting radio waves or ions but the higher you go up the more power you get . It also runs sweet on a carbon rod and a Magnesium rod in dirt . I am waiting for Solar panels and will take orders for Pocketpower+ if anyone still Interested in it after i get them..  Gadget
(http://laserhacker.com/forum/index.php?action=dlattach;topic=63.0;attach=655;image)
NB the 220 pf should read 220 v
Dear sir,
Thank you very much for posting such a great circuit.
I have all the components except the transformer.
Could you please tell me which type of transformer is this?ferrite ? dimensions/wire guge etc
i can quickly check if some body help me regarding transformer.
Bestregards,
D.J
