0 Members and 249 Guests are viewing this topic.
NickZ
  Guys:
   I'd also like to mention...  That I'm now seeing much the same results as Geo has been mentioning and showing all along, concerning the RMG crt.
That is, that by using either the yoke or the flyback core, and connecting them onto the bigger ferrite filled air core, I'm seeing the added brightness and higher pitch of the core ringing, with each additional tuning capacitor that is installed onto the secondary part of the circuit. Balance between these two cap banks is very important, before the yoke, as well as after the yoke.
  So, for those like Itsu, Hoppy, and others that build the "round core", but have not tried or continued on to build the RMG crt.  Please do so, you may be surprised at what it can do.  Geo is absolutely right in everything he has told us.
  Then we can also all work together on the illusive feed back path.
a.king21
Quote from: NickZ on February 07, 2014, 06:24:53 PM
  Guys:
Hey, that's great news. Any chance of a pic?
magpwr
hi NickZ,Hoppy,Grumage,itsu,Geofusion,verpies,T-1000,stivep
I have just uploaded another improved version into youtube to show how i convert HV into intense high current at output pickup coil and perform short circuit test at output without even creating a notable increase in current draw on battery supply as reflected on my digital meter shown in video.
Please forgive the sound as i'm just whispering throughout the video at "night" to describe what i'm doing.I do rarely talk in youtube videos. :-X
I hope someone can further improve on this design and apply it in kapanadze like device somehow."If the no notable increase in current draw do make sense for anyone"
(There is no ou yet.If anyone ask)
http://www.youtube.com/watch?v=VQb6oyRXMrY
(Please see youtube video description for caps details)
Grumage
Quote from: magpwr on February 08, 2014, 09:57:06 AM
Dear Magpwr.
A very interesting video many thanks for sharing it with us.
Would you kindly post the schematic for the HV here for us, a hand scribble will do !!   :)
I have most components to hand and would be willing to verify your findings!!
Finally, did you try an incandescent lamp load to the output ?? It would be interesting to see if a wholesale short changed the input current.   ;)
Cheers Grum.
magpwr
Quote from: Grumage on February 08, 2014, 10:53:12 AM
Dear Magpwr.
Cheers Grum.
Hi Grumage,
I have attached the schematic of my 1 watt ultra simple hv circuit.
This is what the hv to current converter is based on 1 watt hv circuit -Ultra simple hv circuit -http://www.youtube.com/watch?v=BoUivNtYFIA
The key component to efficiency is the triple diffused NPN transistor "H1061" used in my HV circuit.This transistor is quite common in my country.
I have also tried 2n3055 but the "spark length" isn't as great or maybe the 1kohms resistor is too high value to use for the base of this transistor.
I was lucky to find the "hv transformer internal wiring" online using the part number pasted on hv transformer.
For the connection to base of H1061 transistor i tested with 1kohms resistor on various possible points on hv transformer until i achieve the "best spark length" using low voltage at 1.5volts to finalize circuit before going for higher input voltage.
Regarding the copper tube used as pickup coil-
I have tried using a thin wire from a tiny value capacitor and short the output between the pickup coil and noted the shorted wire does get little noticeable warm.At 8volts the input power is mere 3.6watt with good news no notable increase in current consumption upon shorting output coil.
The 1KV 10A spark gap was purchase at around $1 dollar a piece from ebay(bought 7 of those GAS DISCHARGE TUBE - SPARK GAP LITTELFUSE CG21000L 10A 1KV ,seller id: r_francis82 ).I notice by putting more 1kv spark gap in series in my video i used 3 .I noticed the spark at pickup coil become more intense.I can't seems to spot the difference using 4 x 1KV spark gap in series hence i choose to stick with 3 instead.
The best part for using dedicated spark gap it is really "silent".
I think the bigger potential would be to connect "another matching copper tube" or thick copper wire and tap it's magnetic power to kapanadze like device where there is "step up coil,coil for inputting 50 or 60hz(mixing frequency) and etc...
Another weird possibility would be HV to induction heating coil. :D :D :D
