0 Members and 226 Guests are viewing this topic.
GeoFusion
Hi guyz :)
Nick:
Keep up with the progress it will become something of use :) !
Btw the reason I have my primary Heating coil spaced or far apart over the RMG air ferrite core, is that it increases the output ( voltage) and could add more ferrite also.
I will be making vids soon again and to concentrate on that part for you and others that are trying.
But I will be adding a frequency generator soon to it for me to adjust the frequency and see what it does on higher freq. higher then 23-25Khz it gives at output. If I'm correct, it would increase the output load (=.
but lets see what we can achieve.
Hi magpwr:
Glad to see you are also experimenting with Spark Gap tech :p
I have done something similar what I have build and tested to what you have shown us on the video, with spark gaps and using transistor and using pick up coil such as copper pipe or thicker solenoids to output greater Amps at Higher frequencies.
You could try out the Don Smith generator man :).
I will post 2 pics below of the chinese guy replicating it,
using same type of copper tubing but one is CW and the otherone CCW, one is Volts" and the other one is AMPS.
Center tap is ground. It will be helpfull information.
Use the Coil Setup! :)
But the input part is very interesting of your circuit till now, this is something to go deeper into sins it's related to chubinidze and TK's work.
The only thing I miss is those types of caps, 10Kv or higher caps for the device to work properly.
I might order them soon when My Neo magnets come (= so I can continue for a better motor generator and finally record it for you guyz.
GeoFusion
This one will be useful info too (=,
I had this saved when ever I get my hands on Such Caps for the test , but Give it a try man.
magpwr
Quote from: GeoFusion on February 08, 2014, 12:24:44 PM
Hi guyz :)
Nick:
Hi magpwr:
You could try out the Don Smith generator man :) .
hi Geofusion,
I was trying to replicate that Don smith experiment yesterday so i just use 14AWG copper with 80 turns ...90turns on 4.5cm pvc pipe as mention in his site (translated).
Guess what i did not purchase the 6mm thick "copper tube" which is sold as 10meter length over here.I was more concern on storing the remainder copper tube in my apartment. :D
I just use the existing copper tube the short one as shown in my recent video.
I did use 14AWG copper wire to form CW & CCW with induction capacitor.I also ensured the L/C resonance was matching.But unfortunately maybe due to me not using "copper tube" hence i didn't get any positive result yesterday, no serious sparking at all.The spark was just blue.
That's where i wanted to try something different as already revealed in video.
Please don't use that diagram you posted,it's the wrong info.His site contain accurate information but need to use google translate.I have posted his site around 1 month ago in this topic or the another kapanadze topic.I will post link again once i switch o/s on laptop it's 5am+ here.
d3x0r
Quote from: magpwr on February 08, 2014, 04:37:52 PM
Think something that long would be sold in a roll... wouldn't take much space
GeoFusion
hi Geofusion,
magpwr:
Ohh  ok ok you already tried it :) great.
hehe that is good  ;D having your own remaining copper tubing at home for the test.
Same here, I still do have some coiled up maybe around 20 meters of it, but that will come laterz on for use.
Oh ok ok yeah maybe it's because 14AWG for CW and CCW is insufficient thickness or surface to carry alot of amps, as the way how i understand it's effects. But as seen in your vid, the copper tubing is the best :), also tried it with some flyback setup and with home made caps.
But keep experimenting with it!, you are so close to Don's replication :) or to understand a bit more of TK's tech and  able to output alot.
Ah ok, yes I wasn't sure about the schematics untill I try them but I will take your Word for it (=.
Ah yes, :/ contains accurate information for sure, because I have tried some of his theories and doesn't work, but I thought maybe the Don smith one could be good.
By any chens the Chinese Repl. of Don's  as I posted as pics, that one is still ligit though :) but no Diagram still. but can be done.
Everything has to be tested still on many ways and to be recorded/writen somewhere as data and for further progress.
Cheerz~
