0 Members and 231 Guests are viewing this topic.
Farmhand
Quote from: d3x0r on February 08, 2014, 04:57:23 PM
Think something that long would be sold in a roll... wouldn't take much space
The plumbing supply store here sells the 6 mm copper tube in a 20 meter (I think) roll, but they will cut off and sell me as many meters as I want, even 1 meter. It is expensive though.
When it comes in a roll it is much easier to form into coils, the big coils for my Tesla coil took almost no change in the size of the loop, just a bit more curve in it. To roll a small coil simply wrap it around a pipe of the correct size, if the pipe is metal I recommend covering it with some tape or cardboard or something to prevent any nicks or scratches on the pipe.
That drawing looks like the "reverse" Zilano setup. It's just a step down transformer, but good luck with the build anyway. There are problems with that drawing as I see it but I'll keep my opinions to myself.
Cheers
P.S. I think it is important to remember that Don Smith himself stated that the two L2 coils were made from one coil by cutting it and so the two coils were both wound the same way. Don never showed to use CW and CCW coils, at least I never seen any mention of it by him, but I did see him explain how to make the two coils from one and when that is done they both will be wound the same, no way around that, I wonder why people ignore what he says and do something different.
magpwr
Quote from: GeoFusion on February 08, 2014, 05:30:14 PM
magpwr:
Ohh  ok ok you already tried it :) great.
hehe that is good  ;D having your own remaining copper tubing at home for the test.
Same here, I still do have some coiled up maybe around 20 meters of it, but that will come laterz on for use.
Oh ok ok yeah maybe it's because 14AWG for CW and CCW is insufficient thickness or surface to carry alot of amps, as the way how i understand it's effects. But as seen in your vid, the copper tubing is the best :) , also tried it with some flyback setup and with home made caps.
But keep experimenting with it!, you are so close to Don's replication :) or to understand a bit more of TK's tech and  able to output alot.
Ah ok, yes I wasn't sure about the schematics untill I try them but I will take your Word for it (=.
Ah yes, :/ contains accurate information for sure, because I have tried some of his theories and doesn't work, but I thought maybe the Don smith one could be good.
By any chens the Chinese Repl. of Don's  as I posted as pics, that one is still ligit though :) but no Diagram still. but can be done.
Everything has to be tested still on many ways and to be recorded/writen somewhere as data and for further progress.
Cheerz~
hi everyone,
I have attached the circuit diagram for  High Voltage to Current Converter -Improved version 2.0
http://www.youtube.com/watch?v=VQb6oyRXMrY
Please read up the youtube description on my finding on capacitor to use for the pickup coil.***Very important***
hi Geofusion,
I have attached the Don Smith replication done in China.Please take note the video shown is using 1.9mm(Around 12AWG) for the copper wire 80 turns on pvc pipe.
I am using 1.5mm copper wire 14AWG purchased wrongly instead of 12AWG.
There is one typo error on the China site that is copper tube should be 6mm not 6cm diameter if you compared against the background keyboard "Alt" key. ;)
This is the site-Please use google to translate.
http://user.qzone.qq.com/278885050/blog/1378191565#!app=2&via=QZ.HashRefresh&pos=1378191565
Refer to Don Smith China attahcment on just the pickup coil portion-
I have try to create a circuit layout for personal use merely using just the video as presented in China.
This drawing by me might not be accurate as i have not gone through many repeated connection verification via video.
GeoFusion
Quote from: magpwr on February 08, 2014, 10:43:53 PM
hi Geofusion,
Hi magpwr :)
Alright Great  ;D, thnx for posting the schematic man. Yes looks very simple yet it has it's OU capabilities :) just as my Cap bank of my RMG, but this one is done with Spark gap ( silenced one :P )
Try to connect a load like a bulb next time to see results.
Alright I have checked the china site and awesome, those are schematics to be looking into :).
yes it should be 6 cm hehe.
alright awesome, I'm eager to see the test and if you do , pls upload a vid when you are done with a replication of the of the China's and Don's coil, It should give out interesting results :).
Schematic you drew seems to be that it will work :) for sure, but as I see it's to test out where and how to put the caps in many ways for amplification. I will be waiting for the results, as I have orderd these types of Caps to for me to do some further  testings :).
Btw I will be done soon with another Induction motor, will be showing it soon.
Cheerz~
mrzlica
Hi,
If you look the photos, the one with the Vernier Calipers it is not 6mm, but 9mm!
Hope it helps.
GeoFusion
Hi mrzlica
I think you are right :), the measurement is actually showing 9mm diameter.
Although using 6mm can be used too :), all depends what you find to use, It's to get the copper with alot of surface actually
thinking I must have skipped that one to fast  haha.
thank you for correcting.
cheerz.
