0 Members and 226 Guests are viewing this topic.
magpwr
hi everyone,
I have made a another accidental discovery by using HV transformer to power coaxial cable and unintentionally converted my another primary coil 14AWG 80...90 turns into a Tesla coil.
My original plan was to use coaxial cable(Used in Cable TV) as some kind of static charge collector.
The long grey cable show in video is actually leading to my stainless steel running water pipe as the earth grounding.Please don't use electrical earth from plug which do not assist to boost the so called Tesla coil power output.
The power consumption for my attached video is around 4.8watts using 8volts regulated x 0.59 Amps current draw.
http://www.youtube.com/watch?v=e6JbfF2770c
I am more curious how would the arcing be like if i were to use actual Telsa coil consisting of around 1000 turns instead of 80..90 turns while maintaining low power input.
This is the interesting video which i found in youtube which show how natural static in air in room is converted into electricity.
My Tesla's radiant energy collector (open project)
http://www.instructables.com/id/My-Teslas-radiant-energy-collector-open-project/
dllabarre
Quote from: magpwr on February 12, 2014, 04:13:48 AM
hi everyone,
@magpwr
It's hard to read your schematic.
Please clarify.
Diameter of PVC 4cm, 5cm, or 4.5 cm?
HV is what?  1000 volts?  10,000 volts?  30,000 volts?  I'm looking for some idea.
What wave form is the HV that is connected to the 2n2 cap?
Is the spark gaps seeing capacitor discharge from the 2n2 cap?
Here the house ground wire from the MAINS  plugs are connected to the water pipe already.
If I connect to the water pipe it is the same as connecting to the ground in the house wiring.
So this will not work where I live?
Thank you
DonL
GeoFusion
Hi guyz :)
magpwr:
Awesome to see to this try out like a tesla coil, very funny how you used the coax shielding as the part of the ground wire of the  80~90turn tesla coil :). the power consumption is still good sign, try this set up again maybe placing the 10K 0.1uf caps parallel and to see the power increase of the radiant of the tesla coil :).
Make sure to place the ouput of the tesla coil upright, to extract all the Radiant electricity nicely.
I will post some schematics for Ideas that you can try out (=, Sins you have the components.
dllabarre:
Don't use the grounding of the house where mains is connected to. makes the output of the tesla coil dangerous cannot be touched and you can EMP your electronic of your house, as what I have done some years ago, EMP my internet wireless system.
For the Grounding Simply use a rod of Copper or Aluminium or Iron into the ground few 10cm+ and wet the ground, to get the best results for the tesla coil :) only then it can be touched.
check my vid, I simply use a earth pin grounding. Around 2.45 I will turn it on and show.
http://www.youtube.com/watch?v=hSJGez_NhE4
Only to show using the ground that way to amplify the tesla coil as Idea :).
dllabarre
Quote from: GeoFusion on February 12, 2014, 02:17:36 PM
dllabarre:
I have a 4 foot solid copper ground rod outside that I normally use for these experiments.  I was questioning magpwr's statement to use water pipe.
Thanks for your answer.
DonL
magpwr
Quote from: dllabarre on February 12, 2014, 01:18:11 PM
@magpwr
Please clarify.
Thank you
DonL
hi dllabarre,
I know my writing is lousy,hardly get to write in my line of work. :D
Ans:Diameter for PVC is 4.5cm as used in this experiment.If you get little bigger pvc pipe should have no issue as well.
Ans:I think it's around 25kv which i have no measurement instrument to really verify voltage.Although i do know typical tv flyback transformer "maybe larger ones" may go up to 40KV.
Ans:The last time i checked i think my HV transformer was pulsing at around 500hz using H1061 transistor after creating hv circuit.
You will need to refer to my "ultra simple 1 watt hv" in my youtube video for the circuit layout.
I forgot how the waveform looks like.I will post soon if i convert back to "HV to current converter" using 5 turns copper tube.
Ans:Yes from the 2.2nf 50KV capacitor.I purchased 4 x 2.2nf 50KV and 4 x 500pf 50KV caps from ebay.It's always good to have spare hv caps.
The spark gap spacing is important for maximum output,i am using 3 spark gap 1KV connected in series to get 3KV gap.Works best for my case.You will need to refer to my recent posting just few days back on the spark gap specs or my recent video on "hv to current converter".
Since i'm living in a high rise apartment the only "best earth grounding" for my case is water pipe.
The reason i suggested using water pipe for everyone since it would run "deeper in the ground" compared to just sticking 1 rod into ground.
