0 Members and 225 Guests are viewing this topic.
magpwr
Quote from: GeoFusion on February 12, 2014, 02:17:36 PM
Hi guyz :)
magpwr:
Awesome to see to this try out like a tesla coil, very funny how you used the coax shielding as the part of the ground wire of the  80~90turn tesla coil :) . the power consumption is still good sign, try this set up again maybe placing the 10K 0.1uf caps parallel and to see the power increase of the radiant of the tesla coil :) .
Make sure to place the ouput of the tesla coil upright, to extract all the Radiant electricity nicely.
I will post some schematics for Ideas that you can try out (=, Sins you have the components.
dllabarre:
Don't use the grounding of the house where mains is connected to. makes the output of the tesla coil dangerous cannot be touched and you can EMP your electronic of your house, as what I have done some years ago, EMP my internet wireless system.
For the Grounding Simply use a rod of Copper or Aluminium or Iron into the ground few 10cm+ and wet the ground, to get the best results for the tesla coil :) only then it can be touched.
check my vid, I simply use a earth pin grounding. Around 2.45 I will turn it on and show.
http://www.youtube.com/watch?v=hSJGez_NhE4
Only to show using the ground that way to amplify the tesla coil as Idea :) .
hi Geofusion,
The coax shielding somehow did assist to improve the output from my "Tesla coil ...90 turns" :) compared to connecting directly to earth,hv ground from flyback or flyback body.
I used the Cfl bulb to verify this effect.
The original plan was to use the coax cable to collect static charge in order to "amplify power".
I observed in Akula outdoor video there is 2 outer coil which the "larger coil diameter" is way outside the magnetic field.
I am now suspecting his is collecting static charge build up on the tesla coil(top portion) acting as catalyst to amplify power.
We all know that Tesla coil have the tendency to electrify the air especially at the top and at the top portion of the tesla coil.
Another possible reason why in Akula video the outer coil(Around 6 turns as easily seen in video) is made using large diameter is to prevent any interference in the magnetic field and it's made such a way to merely collect static charge or radiant energy as some say.I think he might be applying resonance on the outer coil using cap as well.
I think i have seen this concept somewhere in youtube where telsa coil was used and a receiver coil located nearby with suitable caps is used to power bulb or something.
My upcoming experiment would be focusing on creating a larger diameter wire to collect charge build up on actual tesla coil (top portion)since the current tesla coil i have created by accident is of low radiant,verified using cfl.
I would need to purchase Tesla coil which will take some time since i don't have the "lathe" equipment$$$ just to create this coil.
I have just seen your tesla coil video once more -http://www.youtube.com/watch?v=hSJGez_NhE4
I just notice to get nice output from Tesla coil you used Max "15kv" NST which is connected to variable power supply.
Now we know pulsing tesla coil with higher voltage than mains or battery supply does help to produce even more "radiant energy". :) :)
In the meantime for my case while deciding on purchase which tesla coil -
I now want to achieve this using lower power input.I will need to see if i can further improve my "1watt hv circuit" for better spark for slightly lesser current draw then it is now.
I love tweaking for maximum efficiency.
dllabarre
Quote from: magpwr on February 12, 2014, 04:16:05 PM
hi dllabarre,
Since i'm living in a high rise apartment the only "best earth grounding" for my case is water pipe.
The reason i suggested using water pipe for everyone since it would run "deeper in the ground" compared to just sticking 1 rod into ground.
I was just looking for confirmation of what I was reading.  Thank you for confirming.
Here, our water pipe just goes outside of house a little, then they cut the copper pipe and replaced with plastic pipe to the plastic main water pipe in the street.
We don't have a really good ground anymore.  Actually, if anyone tries to sell a house now, they have to add an 8' ground rod connected to the breaker box because the ground isn't good.
I guess the water department didn't talk to the electrical department before they cut all our copper pipes so short.   :(
DonL
GeoFusion
Quote from: magpwr on February 12, 2014, 05:05:30 PM
hi Geofusion,
Hi magpwr :)
Alright it seems interesting how the shielding of the coax seems to improve and amplify the tesla coil output :). great finding man, it's new knowledge for me too now. It's all about experimenting to know what is possible and what not  ;D. keep experimenting my friend as we all do !
You should try to use the coax as your first thought of it :) electro static collector. see what It can output.
Yes the top portion of Akula's the tesla coil, the Top Load as it functions as a capacitor, amplifies the field and charge :), using the aluminium as the catalyst. Yes, the larger electro static collector recieves those amplified static charges from the top load of the tesla coil.
Yes akula has his ways how to tune the resonance with caps and circuits where I still mis  a bit of complete understanding befor I can replicate them, but I do understand how it functions and most of us.
I thought the 6 turn large diameter coil should be the collector of the Elector static charge and to amplify within  the bifilar multi-layer with caps for output ,  as I have done some experiments like that , but again he uses ferrite cores if you have seen them that are directly connected to the collector coil aire core. There is something that I still want to understand to that part but I t will all come :).
I  self have tried many ways how to collect the Radiant energy how Tesla described in his patents, such as using a good plate of aluminium or copper with great surface ( the more surface the more charge for the bulb).
we know if we place a second tesla coil near the first one, the second one will collect and also output, even if the second one is not even grounded, and with a extra coil around it with same amount of turns of the primary of the first tesla coil for output. :)
Alright :P looking forward to the next tests, Btw I will be sharing some pics and Ideas for you, that I think Is of great importance to try them out and see if it works :).
I have Schematics/diagrams of Chubinidze coil, That uses these spark gaps, KV caps and bifilar with resonator to get a massive output of some Kw power out.  I have the coild built already here, but I miss the 10-50Kv caps to do the test.
I will be recieving those in a bit so I can also Do some work on it an tests.
Btw could you post your simple Hv driver schematic? I do have my version, but your's seems quite simple ;).
Ah thnx man :), yes the output of that particular tesla coil of mine is simply beautiful. The radiant energy it output's  is something very awesome to analyze and to experiment with and to know bit more what it can be used for :). Unless you have a motor magnet generator that outputs enought Kilowatts to waste , you could use the 15KV system all day long without using mains. hehhe :p
Yes Keep building up the 1 Watt Hv circuit :P, I find it interesting and to progress with it sins it ( again ) has a potential for good OU capability. Of course for the better Efficiency!  keep it up (= I will help with Ideas too.
cheerz~
QuoteI have just seen your tesla coil video once more -http://www.youtube.com/watch?v=hSJGez_NhE4
That video shows some very dangerous activity going on. It's a good thing that the "tesla coil" shown isn't working very well, because the person who reached out to grab it would be suffering from very painful and slow-healing RF burns to the hand. If not being completely electrocuted, by the HV from the primary NST supply mixing in with the RF from the coil.
FYI, if you have a welltuned TC that has absolutely no chance of any leakage (thru arcs, bad caps, etc) from the primary supply to the secondary, you can use your body as a conductor to ground, but you should -NEVER- take the discharge from a high-powered TC directly to your skin the way the person in the video is doing. Grasp a hefty metal object like a wrench or screwdriver firmly, and let the spark go to the object first. This will protect you from the painful RF burn. It won't protect you from dying, should your primary supply arc over to the secondary down low, though.
Tesla coils, especially those powered from the mains, can be LETHAL or cause very painful injuries. Using a NST, which is typically current-limited, helps for safety. Using MOTs is particularly dangerous as they are not current-limited. That is not a Slayer Exciter there being played with, that is a real attempt at making a mains-powered SGTC, and some real knowledge is required to maintain safety and to obtain good results.
When working with high voltages and high frequencies, a neat layout and careful workbench technique is a must, for safety and consistent performance.
http://www.youtube.com/watch?v=tTLFlRhsa5U
a.king21
Re: Reason for coax and earth ground in the Kapanadze devices.
Some experimental proof is coming on vid, hopefully today as Grumage and myself have cracked it.
Expect a vid soon.
