0 Members and 1020 Guests are viewing this topic.
Farmhand
Quote from: magpwr on February 16, 2014, 08:17:33 AM
hi Geofusion,Grumage,
I have found a interesting video which reveal how to light up incandescent bulb brightly using aluminum foil(Used as collector) and earth  near Telsa coil.
The Telsa transmitter is using mere 300mA.
It's a proof if it's static or some kind of rf or electrical field.
http://www.youtube.com/watch?v=k8XCyQk4LGQ
Another video from same user is using Telsa coil output to boil water in tube with steam produced.
This is 1st time i have seen this unique effect.
http://www.youtube.com/watch?v=MR5V5JrJZ3Q
Perhaps you'll enjoy this clip then from the plasma play labs. I get a filament inside a bulb to spin fairly reliably using a Tesla coil "field".
The Plasmneto effect I call it for fun. http://www.youtube.com/watch?v=Ml_qlvD5N9E
And by the way that arc stream is hot, if a bulb is held in one spot too long it just burns a hole in the glass, I got a very quick but painfull high frequency arc burn to the back of my finger from the windings on the coil near the top. If a arc like that is held to a fingertip it will vaporize skin and flesh pretty quickly, as well as cause serious pain, lucky mine was powered only from a battery.
Cheers
verpies
Quote from: Farmhand on February 16, 2014, 11:34:57 AM
Bring permanent magnets close to the bulb for even more plasma fun...
NickZ
   Guys:
   I'm still working on the RMG circuit replication.  I've just made a 4th video showing the device lighting up 6 100 watt bulbs, and I also hung another 60 watt bulb on the output and got 660 watts worth of bulbs going, to partial brightness.  I still need the right tuning caps,
and the right turns ratio on all coils for the best output, but I'm working on it, slowly.
  Here is the link to my last couple of videos, and my new YouTube channel.
   http://www.youtube.com/watch?v=QbSJx91vtO4
    My Channel on YouTube:
         http://www.youtube.com/channel/UChwfL5U16oZ20H6zuW-LIHg
GeoFusion
Hi guys  :)
magpwr:
Nicee, yes I have done similar tests :) with my 12 to 48 VoltDC tesla coil with the same plasma (hot) coming out :), I think it's very efficient using a large suspended Aerial plate to collect and charge more static radiant on the surface of the metal and the bulb will increase brightness :) btw where he hold's the bulb is actually grounding for the bulb light up ( human grounding for what he is doing)
I have even let sometime a remote controlled drone work on it while placing a large circular aluminium foil band around it to collect energy and it will fly near the tesla coil, it is totaly powered by it, using the zeners or germanium diodes.
I think I should up load a bit of that material too :) hehe.
As for CFLS, on 36 volts tesla coil, I managed to light up 600watts worth of CFL ( gues could light up more ) and fully bright.when close by.
The tesla coil with the boiling water in test tube is an interesting idea :), make me wonder if I could produce HHO with it somehow. Thnx for the links
Farmhand:
the Plasmneto effect is awesome  ;D, I had a bulb that did something similair to that, but had one that also imitated as a solar flare, it's wicked and how to control the flares inside.
But the effect you have shown is awesome yet funny for the spinning of the filament inside hehe.
Yes those arcs are very hot, haha been there too, holding a 7 watt bulb and it burned holes in the glass!! finally I could relate some of my experiences  ;D
I used one smaller tesla coil to output a high plasma burst out on 48 volts to cut thick plastic for the test of intensity of the heat. It is not a toy at all, very hot. would smell the burned skin if you even dare to touch it for a while, nothing compare with a sparking gap tesla coil as what I have experimented with and is ok while touching as we see (= but it's because of the HF oscillations that makes it hot. same here all batteries here hehe
Nickz:
Hi there, I see you progress with the RMG replication  ;D
Great job man, about 660 watts not bad :) it shows potential.
Alteast it lights those up to show it can, now to step up the frequency and caps for better resonance match.
I will be somehow attaching  e 555 frequency module or better. To the mosfet circuit to try to tune the resonance see if there can be a better resonance.
Btw something I wanted to point out, on my RMG aire core with ferrite, the Exciter coil, thick copper wire is a bit streched of the output coils, because it outputs more when it's somehow equally spread with a certain distance over the coils.
Try it with your RMG, while the circuit is running, try to displace the coil over the coils, You might see increase in brightness and voltage.
But awesome job  8), you managed to make it work with the CRT tv  ferrite yoke, is the first.
I will make some pics for you again for the caps that I have at close up.
Btw try to connect other transformers to the  coils see what it does.
and try to put higher input voltages too when you are ready, maybe till 24 volts, but be careful  ;)
Cheerz~!
NickZ
    Geo and All.
    Thanks for your comments.
    I think that the important part for me on the ongoing RMG project, is to correctly match the coil turns ratio on all the coils used, for optimum output. And the use of proper tuning caps to reach the best resonance levels.
Then to focus on a working feed back path.  My idea on that, is to make a feed back coil on top of the other coils, that once its output is rectified it will then return a total of about 18 or 20 volts back to the primary input side of the yoke core, along with some amps as well.
So far, on my RMG circuit as far as the feed back circuit output, seams to be well accepted at the input side of things.
   Geo:  What happened on your SR 193 coil tests?
   I think that the RMG circuit, using lower voltage, and higher amps, but using this non shocking current is the best way to go.    Safe!   No interference to nearby electronic equipment.   Almost magical how it works.
