0 Members and 62 Guests are viewing this topic.
gmeast
Quote from: forest on March 05, 2014, 12:15:33 PM
Maybe 1W and a big coil is not attractive, I'm sure something like that can be easily "faked" by tapping radio waves from transmitter. 1W is just too low to be a real proof
Hi forest,
Radio waves can indeed be easily trapped and used as a ruse. Go to my YouTube channel and see my Radio Motor. I built this stupid little motor specifically to run on radio waves ... but NOT as a ruse.  Go to YouTube and type gmeast and you'll get a link to my channel.
Regards,
gme
Every one of the circuits I've seen in the various Kapanadze threads has the basic elements of a wireless power transmission/reception system. In fact the circuits, with a little bit different output arrangement and some actual power input from batteries, etc,  would be pretty good wireless power _transmitters_.
Think about it. A big cable transmission loop, maybe masquerading as a clothesline up above or over to the side of the demo, or a cable in the ground looping around the demo area, driven by an almost identical oscillator-driven multivibrator kind of thing but with real power input, could probably power the receiver circuits directly over the intervening distance.
Unless and until this kind of hypothesis can be positively and absolutely ruled out,  you will be bothered by skeptics like me who just want to see Kap's or Akula's monthly electric power bills, or something.
GeoFusion
Hi Guyz, magpwr, Nickz.
Yes, the Akula circuit is real, because I can relate it a bit with my TROS system replication of Igor on how the transistors function  and how the base of the transistor is connected to the tesla coil winding part where the other end is connected to nothing but only to transmit frequency and energy within the toroidal field.
I will try to replicate it soon too.
But that Schematic is the real thing for sure
at some point I see there are some components that can be left out and can still work.
magpwr:
I saw this compilation vid and this should be the way to go with the 1 watt HV HF circuit
Chubinidze Compilation of OU coil and Self feed.
http://www.youtube.com/watch?v=5nxKqfkkndw
Chubinidze style :), it has the right schematics for it, I have found some additional info about the resonator,
it needs to be positioned inside on the right spot for best results of resonance.
so moving it back and forward inside.
You already have HV caps :), that will do the trick but the windings are easy.  Give it a try.
I have done a similair test but with low value caps, and it works but I need HV caps for it to be OU.
I am getting my HV caps soon so I can finish mines for the test.
But also almost done with new circuit for the RMG style circuit. It will look a bit like akula system.
cheerz
Grumage
Dear All.
For the electronics guys amongst us. And Akula0083 fans !! A NEW thread.
http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/new/#new
Cheers Grum.
magpwr
Quote from: GeoFusion on March 05, 2014, 05:29:08 PM
magpwr:
Chubinidze style :) , it has the right schematics for it, I have found some additional info about the resonator,
You already have HV caps :) , that will do the trick but the windings are easy.  Give it a try.
cheerz
hi Geofusion,
I think i have spent around USD 700 for various HV items.
The most expensive and the important item is the 40KV 20MHZ passive probe for my oscilloscope.This will allow me to ensure that i will not cross the hv capacitor rating and for the first time i should able to
see what high voltage or frequency i am running at.
Large HV caps for don smiths and Akula.
800w Resistive dimmer on the cheap <$10 to be used as variac for NST 220v 10KV,30mA,30KHZ.
and many other etc.
All the items are in the mist of delivery to my place. :)
There is nothing much i'm doing in the mean time except research and more research as i have sorted out what i need to do in my head.
Akula and Don smith project.
