NickZ
   T-1000:
    I will answer you on this thread, as I don't want to discuss the Mazilli/yoke set up on a thread that is dealing with another device.
   I don't know if I totally understand what you are suggesting, but I have some idea of what you are saying.
   First of all, what I'm working on is a feed back path for my version of the replication of the GeoFussion device.
As that is a flip-flop oscillator circuit that can output a fair amount of energy and especially a fair amount of current. And is also the best circuit and core set up to date, for me, so, I don't want to change that too much right now.
I would like to work on making a functional feed back loop, for that crt, that works. That is what I'm most  interested in at this time.
  However, I have reviewed and studied your suggestions, and I'm not against trying some of them on a different or separate yoke core, but connected to my existing set up.
Why the yoke? Because it provides for higher output than anything else that I've tried, and I have several of them, as well, to make further tests.
  Now, last night I connect a separate yoke, a slightly smaller one to the output of my existing Mazilli/yoke set up. This second yoke was also able to light a 100 watt bulb, although dimmer that the primary yoke core, as the smaller yoke has less turns. And the idea with it, was to rectify this second cores output, and feed it back to the primary yoke input.
What happened was that this second yoke core, did create the chatter that you are mentioning. While also dimming the output of the bulbs connected to the primary yoke circuit. At one point I did notice a higher lumin output from the primary yoke crt, which was stronger than what I have seen previously. I'm still working on getting this higher output back, as I'm not sure what caused it, as it continued even when disconnecting this secondary yoke core, and left only the first yoke core circuit connected.  It's possible that this second yoke core triggered this higher output, somehow, even though I disconnect this second yoke crt, but, the higher lumin levels continued on the first yoke core crt.
Although the chatter, ringing, hum, or vibrations are not always needed for this to happen. This second core vibrates, and hums (like Hoppy likes to see), but does not ring, at least not yet.
  Anyway, I will continue with these test today, to see if I can observe anything worth mentioning here.
  I will also try to rewind the second yoke core with 1/4 wave, or at least 1/4 the amount of turns on this second yoke's secondary primary coils,  to make it into a two primary yoke coil, with a single secondary coil, as you suggested.
   As you may know,  I don't have a scope. Looks like you have a great one though, if the pictures are of your scope. So, why are you not trying some of theses ideas yourself? As it would help those of us that don't have such nice test equipment.
   Any ways, thanks for your suggestions. I will do what I can with it.
   NickZ
MenofFather
One guy replicated Dally divice http://www.youtube.com/watch?v=pWfVnJ1sEms
Shine 500 W projector with selfrunning. Ground is important, then he remove ground, burn up his power supply. He using power supply in video 5 amps, probarly 12 volts. Say, that using small energy wery. (in other his divice he use 10 amps 24 volts supply). Say that burn wery much transistors, who makes nanosecond puses... And dificult ajust. How he say. I not give waranty, that here not fake.
Hoppy
Quote from: MenofFather on April 21, 2014, 02:33:54 AM
Another very iffy demo from a member of the barefoot brigade.  ;D
NickZ
  At least it shows that even barefooters have a chance at free energy.
   Maybe,  he takes off his shoes so that we won't think that they are full of secret hidden batteries.
  I would like to see his higher output device, (24v, 10 amp). Is there a link to it?
  Here is a link to a similar video from him, but outside this time. Although he should have moved the test further from his car (12v source).
  https://www.youtube.com/watch?v=01Sf1pZuHn0
  Good to see more and more of these types of videos. And a another Daly device with no special coax cable.
  I still don't feel that they are faked. At least nothing to indicate that, as far as what I can see, or understand.
