0 Members and 52 Guests are viewing this topic.
Jeg
Quote from: NickZ on May 12, 2014, 09:37:57 AM
  Jeg and All:
  Thanks Jeg. I would recommend pursuing this type of simple oscillator circuit.
  The bigger the yoke core the better the circuit will work. I don't think that the ringing or core vibrations have anything to do with the higher output, but are a consequence of this alternating flip-flop circuit instead.
Try to obtain the 0.33uf 400- 660v caps if you can, as many as you can get, at least a dozen of them or more. Place half of them on the input side, and the rest on the output side of the yoke.
  I believe that the non-shocking magnetic output of Mazilli/yoke core combo is the heart of a working self-running set up. Hopefully I will get to prove that, as well.
  Looks like the feed back loop should be composed of a feed-back coil, full bridge rectifier, and one or more capacitors. Also, you'll need to buy some 18v 5 watt zener diodes, instead of the lower voltage/wattage ones, or you'll burn out the Fets, with the additional energy sent back to the input from feed back loop.
  Good luck,
                      NickZ
Tnks for the advice. What frequency you run it to?
Yesterday I made the chock ringing at 5Mhz while the output coils were pulsating at about 250-300khz. I put a secondary to the chock and after a tuning cap and a diode, I charge a cap at 65v. I then connected this 65v with an lm7812 but the voltage went down at about 10volts. I will try it again with different coil turns and an earth ground to see what will happen.  :)
NickZ
  Jeg:
   I don't know what frequency this device is running at. Nor am I trying to tune to a certain frequency. The caps along with the number of coil turns, as well as the tuning magnets can effect the frequency substantially.
  I look for the brightness of the bulbs as an indication to tune to, but neither the ringing sound or vibration mean much, as far as I can see. Although the loudness of the ringing does seam to indicate something at times, but the ringing is not necessary or essential for the system to run as best as possible. As I can get the same amount of lumins even without any audible sound or vibrations from the core, at least to my ears.
  I'm not trying to tune for nuclear core/or copper resonance factor, based on nuclear core or copper decay, at all. And will try to avoid that at all costs, if that be the case.
  After months of testing at close proximity to the device, I have not noticed any negative effects from radiation, nor have I been shocked by this device, ever.
Jeg
Ok Nick, I find it an interesting toy! I will also share if any improvement ;)
rc3po
I have an oscilloscope and equipment. I need to get more components, transformers, cores and stuff.
magpwr
Quote from: NickZ on May 11, 2014, 12:01:58 PM
  As promised, here is a video of my circuit lighting up 650 watts of incandescent bulbs. I have managed to light up to 700 watts, but with each additional bulb the total lumin level does start to decrease. The best brightness is obtained when using 3 100 watt 110v bulbs. Input source is an old discarded 12v 4aH battery.
I'm still working on a suitable feed back loop. Any suggestions are welcome.
  https://www.youtube.com/watch?v=OCcTInm_EPI&feature=youtu.be
hi Nickz,
Great job man.It seems even if i take 650watt/2 =325watt then divide by 12volts=27(Cool Amps)
If try to calculate output at 1/4 of 650watt load = 162.5watt then div by 12volts.The Amps is 13.5 which your battery as mentioned is mere 4Ah only.
I know these non motor starter battery can't crank higher Amp than it is rated for.
Please do not try using any bridge rectifier at all.My discovery all the bridge rectifier are typically design for 50/60hz only although can nicely do 400hz.
Even the datasheet reveal facts.
I am not sure if you create a step down transformer using ferrite core and use fast response high Amps diode 400v or 600v >20Amps with series with a self made Air core inductor to loop back would work.
In one the youtube video in Russia-a air core 18awg coil around 20cm high then the top of the outer coil is connected to top of inner coil.The output from the bottom of inner coil is driving the 220volt motor with caps.
