0 Members and 158 Guests are viewing this topic.
NickZ
  Gyala and All:
   As you are still thinking that I'm working with the two yoke circuit, I've uploaded these pics so that you can see that the current tests are using the flyback core instead of the smaller yoke. I'm using the flyback because it was already wound with a center tap. I'm using two UF 306 diodes, which are staying cool, at this time, although I can't run the circuit over a minute due to overheating of the Fets, still.
  I have taken another turn off of the SECONDARY (not the primary as you were thinking) of the flyback. Also connected it to the 200v 475uf capacitor, choke, and using a 24v 18w DC bulb as a load. There are now only 3 turns on either side of the flyback center tap SECONDARY coil.  There is about 30 volts rectified DC output at the bulb connections, IF this meter reading can be trusted. So, I will further remove another turn on each side of the center tap to bring the DC output voltage down to about 12v. I already burned a 12v bulb in the test, so I'm using the 24v DC bulb for now, until I can further manage reduce the DC output to 12v. There is also directly connected to the yoke output 5 110v, 100w bulbs, running at the same time, as well.
The system is working as is, the AC bulbs are fairly bright, enough to light my small house, and the 24v DC bulb is real bright, too bright still, at 30 volts.
  I hope that this helps to understand the current set up. Which is also being changed constantly, each day, as I continue with these tests.
  Magnetic current MAY possibly be read by a volt meter, once filtered and rectified, although I'm not trusting any meter readings, yet.
        NickZ
NickZ
  This Russian guy has made several blurry videos, which look like the Akula type of replications. It's worth looking at them when you have the time. Wesley has also made a translation of at least one of these videos.
The guys also said that he won't answer any stupid questions, nor explain just how the device is working.  But, it works,  so he says...
  He is also showing this same device lighting up to 10 100watt bulbs on his latest video.
  Take it for what it's worth, but, I'm sure the time will come when we'll get to the bottom of all this.
  https://www.youtube.com/watch?v=59o_M6U9Un4
  https://www.youtube.com/watch?v=hY-OC9yFcCU
Hoppy
Nick,
A couple of lads having a laugh in that second video.  ;D
Hoppy
Quote from: stivep on May 27, 2014, 03:09:56 AM
https://www.youtube.com/watch?v=_NVBiY13osE&feature=youtu.be
Wesley
Wesley,
Thanks for posting this update on the Dally device.
I feel that Dally needs to repeat his video in a much more controlled inside environment, making sure that the 'earth' wire is disconnected and re-connected in close-up camera view before his device is likely to be taken seriously as a possible self-runner. As I hope you appreciate, that given we rarely see this performed in videos in a controlled environment, its really a nonsense that they are posted on the fora with the intention of being taken seriously. These guys really do need to up their game.
