0 Members and 509 Guests are viewing this topic.
Hoppy
Thanks for your reply Wesley. I'm glad to hear that you are exercising free will with the posting of videos.
Its up to you whether you wish to explain why you take so much time and effort in doing this.
gyulasun
Hi NickZ,
Good progress and thanks for the pictures. Now you know that a 1 turn secondary gives about 12V output and I understand you thought to get around 12V rectified and puffered output voltage which sounds like enough but this may not prove enough for the feedback. I mean now the next possible step is to load this 12V output with as high current as your total setup consumes from the 11.5-12V battery input. And if this 12V output is able to supply that much current and remains around 12.5V-13V like the input, then you could attempt to loop back via the series diode I indicated in my drawing. The 1V higher voltage is needed because it will be lost across the loop back diode.  The big question before a looping attempt is whether the input current increases when yout start loading the secondary output by as much current as the input itself takes? (I mean loading the 2 x 1 turn secondary of course.)
Now your diodes and puffer cap are not heating up much but a little?
Gyula
NickZ
    Gyula:
    Thanks for your reply.
    The next step for me so that I can be able to run this circuit for longer than just a short while, is to obtain the 18v 5 watt zener diodes that I have previously mentioned.  Hopefully this will allow the circuit to run without overheating the fets. The double single turns of the secondary of the flyback can be further tuned slightly higher, let say to 15 volts or so, then. Also the yoke (smaller one) can also be used to replace the flyback, as I know that it can output higher current levels than the current flyback can. So, far I feel no heat emitted by the UF 306 diode rectifier.
  I will try to order the zeners tomorrow, along with some 12v bulbs, if possible.
  Thanks for staying with me on this effort.
        NickZ
Acca
QuoteThis Russian guy has made several blurry videos, which look like the Akula type of replications.
His name is Ruslan Kulabuhov.. photo below, and if you would look at the video where he is in a parking lot and a ground is connected it he explains that you need a ground..
His ferrite core has shattered twice and it was very hard to find the right one !!!
So far "he" is the only person who UNDERSTANDS the physics, like he says "you need to understand it to make it work .. Suggestions that  one should interpet this clip(s).
Acca...
[/font]
NickZ
  Acca:
   Thanks for the info.  I have seen the video that you are mentioning, although I could not remember his name. He, Rusian Kulabuhov is not the ONLY person that understands the technology, there are others. Probably many more than we are even aware of. Such as Stepanof, Akula, Dally, SR193, Kapanadze, Chubinidze, etz... Mostly all Russians, as they are not brainwashed into thinking that this type of devices are not possible.  I also have Slavic blood running through my veins.
There are some guys that don't post videos, or post in forums, and are not interested in fame or fortune, just want to have free electricity for their own purposes, like myself.
   If you have not seen the latest Akula home video that Wesley just posted, I suggest you do so. It might surprise you in a positive way. It certainly did for me, although I never ever doubted that Akula's first two devices were not real.
Now we know for sure that they are the real thing.
Thanks to Wesley for posting the translation. Best news yet...
