0 Members and 513 Guests are viewing this topic.
magpwr
Quote from: Acca on May 28, 2014, 08:16:14 PM
His ferrite core has shattered twice and it was very hard to find the right one !!!
hi Acca,
Since there is a mention of "specific ferrite core" ,flawless ones maybe.Now this bring us back to Akula video which is using yoke core as catalyst.
"I know there was a hot debate  going on previously about specific ferrite cores used"
May be Nickz found a right yoke core by chance which would serve as a "primary  catalyst" for the ou device.
Since my memory is still good which i recall in one of wesley translated video for Akula whom mentioned the yoke core releases "beta wave".There seems to be emphasize on yoke core by Akula then which many of us ignored.
I am still feeling bitter since i can't get my hands on Rubin yoke core from Russia.I think Nickz have given us new hope of finding a suitable yoke core.
My findings on Mazilli circuit is that it will use the  "LC" combination eg:coil+capacitor in parallel to run at that resonant frequency.Another findings related to Mazilli in open circuit the idle current drawn is further reduced upon using the right capacitor around 0.2uf...0.6uf with coil.
Hoppy
Quote from: NickZ on May 28, 2014, 09:09:38 PM
   If you have not seen the latest Akula home video that Wesley just posted, I suggest you do so. It might surprise you in a positive way. It certainly did for me, although I never ever doubted that Akula's first two devices were not real.
Now we know for sure that they are the real thing.
Thanks to Wesley for posting the translation. Best news yet...
Listening to Wesley's comments in the first part of the video, I'm not so sure that he was so very impressed as you are with this demonstration from Akula. Anyway, keep at it Nick, as you may one day be able to demonstrate a working device like Akula and hopefully one that does not require NMR to self-run. :o
Jeg
Quote from: magpwr on May 29, 2014, 04:53:49 AM
Well done Nick! I am so glad that you make this progress, and so glad that Guyla is involved on this as a team work is always better than moving alone on this field.
By reading Magpwr's post, i recalled something that still is a mystery to me. It is an effect that farmhand reported before a month on Akula's 30W thread, and it has to do with the tv yokes. I replicated this experiment and it is just astonishing to me! Perhaps some of you can help to analyze it. Farmhand had made two coils of 100 turns on each half of the yoke core. At 1MHz, he noticed a very high amplitude peak at 200V at the output, just by feeding the primary with 18V from a signal gen. In my replication, with 150 turns on each half, at 237KHz i take an output of almost 600V pk-pk with just 10V square input. You guys find it normal? Think that both coils have exactly the same turns. For me, something happens inside the core when we are in resonance.
magpwr
NickZ
  The suggestion of first knowing and understanding just what we are trying to achieve with these devices, before trying build them is valid. However, who knows what is really going on? Even Akula mentioned (Earth) magnetic resonance at first, then suggested NMR, then...
   My suggestion for those that have Tv yokes available is to try it and see. Try to find the biggest yokes possible, like the ones that come on the older 34 inch Tv. There is a reason that the bigger yokes are used in the biggest Tvs. They output more power, given the same input source, compared to the smaller yokes.
  I have three yokes, two are about 3 inches wide, one is about 2.5 inches. They ALL work, to produce a good current output. Of course the bigger ones work best.
  I have ordered some zener diodes, as well as some 650v 0.33uf tuning caps, from some local distributors, we'll see if and when I get them delivered. If not, then I'll have to have them brought in from the States.
   The Mazilli/yoke circuits running frequency can be adjusted, by the use of these tuning caps, adding or removing primary and secondary coil turns, using magnetite magnets at the core, etz. That is what I am doing in my yoke circuit.
   Those that also have access to circuits that can control the duty cycle and adjust the running frequencies, would be of further help.  Although, I doubt that TK had such equipment for his earlier device, which showed higher output than these later much more complicated designs that we are seeing now.
  I still feel that the original TK device (buried radiator) was for real. Before politics and BS got involved. The Earth ground may be essential for higher output, even though Akula showed his first device running even without a ground connection.
   I'd like to know, if possible, if the new tests that were conducted at Akula's place also proved that his second device can run for an unlimited amount of time, stable, without overheating, unlike his first device, which could not.
  Edit:
   This video below is a working replication of Akula's second video device.
You may have seen it before. Or forgotten about it, anyway,  he explains a bit about how it works, the input and output levels, etz...
  I wish that I could understand it, or clearly read the meters, but the guy does nice clean work.
   https://www.youtube.com/watch?v=Y8snEOzF9R4
