0 Members and 348 Guests are viewing this topic.
Hoppy
Quote from: NickZ on June 20, 2014, 06:41:57 PM
  It would be best to focus our attention on just one proven circuit (like the Akula 1500 watt circuit) as that one has been confirmed as authentic. And to work together on this crt, if possible.  Too much to ask,   I know.  But, that is what some of us here did with the first Akula circuit, before all the comments of fakery and such. Which did not help much at all, and possible was in part responsible for taking the wind out of our sails.
But, the wind is blowing, once again.  For those that put their sails up.
   NickZ
??? Akula 1500 watt circuit confirmed authentic?? That's news to me Nick! I cetainly don't feel a fair wind blowing for the motivation to continue replication of Akula's devices using his incomplete and misleading circuit schematics.
MenofFather
Quote from: d3x0r on June 20, 2014, 05:32:34 PM
Well thanx; but that part I was mostly certain of :)  What about all the other things ending with a ?  ?
Okay I see; there's a difference between the '50 winds' total and '48 winds each' ... so the outside is 25 and 25, which makes sense to make it fit...
any opinion on the direction cw or ccw of the kacher?
Kacher secondary seems wound in same direction like inductor. If for you kacher not works, then just replase ends of inductor.
Were conected red winding on yoke I don't know if you about this.
I some you questions not  understand. I can say, that here not 48 turns, but 56 turns and other is not corect turns of layers in schematic.
How much turns secondary of kacher have I not know, but think, that about 500-1000 turns. :)
MenofFather
Quote from: d3x0r on June 20, 2014, 07:56:30 PM
In that last schematic what is the big bold "F1" ะค1  ?  Frequency?
ti seems to be a choke-transformer... but no specifications... if I use a 1:1 toroid transformer of I dunno 100-200 uH is good maybe?
Here is filter, it not nessary in general. :)
d3x0r
Quote from: MenofFather on June 21, 2014, 05:36:33 AM
Schematic says 200... but hard to know... I have coils with 1000 (28 gauge) that work well... before applying the filter the new one that was only 200+(24 gauge) and
But; the induktor loops back on the right side so it looks backwards to the kacher secondary... some of these things are really hard to see... where you should be able to see it in the highres pictures it ends up being blocked by other things
could wish for a shot through the tube
Edit: I see you labeld parts 'inducter' and 'antenna' ... I see nothing on the schematic that is 'antenna' what you labeld as inducter is actually the driver of the kacher.
Edit2: ran the kacher without filter, with indukotr attached, noted the frequency... made another filter with fewer windings... started at half, ended up at 1/3 the windings so the frequency then matched the kacher... now works.  it's about a x200 coil  (4v input, 800V p-p, 14V input, 2800V p-p output... ) The filter does help current draw.
Question though; is there a convention for CW and CCW notation?  Is that looking at how the wire is coming off of the coil? or going into a coil?
Is the kacher HV coil the same as the first layer? or the outer layers?
Jeg
   NickZ
Nick is it possible to attach the schematic of Akula 1500W?
Well done with your national team!  :)
