0 Members and 556 Guests are viewing this topic.
NickZ
   Although there may not be any certainty of Akula's circuit diagrams,  there may be enough information presented already, for those few of us that don't need to be spoon fed.
   Following what we can see from the video(s) of the second Akula device,  which was also confirmed to be a true working device by Wesley's friend Tiger, may be the best bet, so far. Or, if you have a better idea... please post it.
   There are no EXACT and true replication of any of Akula's higher power devices up to now, at least that I'm aware of. Or confirmed schematics.
  The 1500 watt device may be the best example of a current still working self runner to date. It may still need further improvement for it to run non stop, stable, and without overheating, etz...  Those issues were not mentioned or confirmed by witnesses.
MenofFather
Quote from: d3x0r on June 21, 2014, 06:00:21 AM
Schematic says 200... but hard to know... I have coils with 1000 (28 gauge) that work well... before applying the filter the new one that was only 200+(24 gauge) and
But; the induktor loops back on the right side so it looks backwards to the kacher secondary... some of these things are really hard to see... where you should be able to see it in the highres pictures it ends up being blocked by other things
could wish for a shot through the tube
Edit: I see you labeld parts 'inducter' and 'antenna' ... I see nothing on the schematic that is 'antenna' what you labeld as inducter is actually the driver of the kacher.
Edit2: ran the kacher without filter, with indukotr attached, noted the frequency... made another filter with fewer windings... started at half, ended up at 1/3 the windings so the frequency then matched the kacher... now works.  it's about a x200 coil  (4v input, 800V p-p, 14V input, 2800V p-p output... ) The filter does help current draw.
Question though; is there a convention for CW and CCW notation?  Is that looking at how the wire is coming off of the coil? or going into a coil?
Is the kacher HV coil the same as the first layer? or the outer layers?
I not speacialist in this questions, you must ask this questions to Akula.
But I can try answer.
If I good understand, then my answer is in picture.
Akula in one conference say, that without synchronisation not work. If you use kacher, here is no synchronisation, so acording Akula, that must not work. You can try made like in schematic, but here is probarly wery small chance, that you get overunity. So I not wery see reason wasting time anwering you questions about divice, who I belive that for you not works.
"[size=78%]is there a convention for CW and CCW notation?"[/size]
This question I not understand, if try answer questions.
"[size=78%]Is the kacher HV coil the same as the first layer? or the outer layers?"[/size]
[size=78%]This also. Kacher, I think probarly have 500-1000 turns, and then 3 turns of tick wire at end to fix it, if you about that giving question.[/size]
tarakan
Someone is fooling you. This coil is rather complex. A lot of windings.
The inventor of this coil must have been a messenger of god. He is Jesus or Muhammad or a similar kind of charachter.
How else could he come up with such a complex device at home, in his living room?
And like an orderly Prophet, he gives you part of the theory, but never explains everything about this world.
So the only approach would be to find this theory of operation ourselves, collectively, through measurements and calculations
and not to try to decypher fake BS.
Jeg
Quote from: NickZ on June 21, 2014, 11:37:38 AM
Thanks Nick
I personally don't see any reason if there is even one Akula circuit that woks as OU, the others to be fake. I mean, if you discover a working principal and you know how to make an OU generator, why to make 9 more fakery ones?
I have a question to any of you who have  experience on phase shifting measurements between voltage and current in power lines. If current is already behind voltage to some degrees and then we feed an inductor, then this current would slow down more isn't it like that? When I measure in my oscilloscope the output signal I measure voltage right? First, how can i be so sure that also current is loaded with this high freq. Component on the right moment? And of course second, how my output coil can be loaded with current in a specific short time duration if this is behind voltage in a more degree than the appropriate? Then I guess that voltage would be applied at the ends of the coil and before current would start to increase, then voltage would reverse polarity, and every time before current would do the job, voltage would change polarity. Does this idea belong to reality?
x_name41
