0 Members and 556 Guests are viewing this topic.
d3x0r
Quote from: MenofFather on June 21, 2014, 12:26:58 PM
I not speacialist in this questions, you must ask this questions to Akula.
But I can try answer.
If I good understand, then my answer is in picture.
Akula in one conference say, that without synchronisation not work. If you use kacher, here is no synchronisation, so acording Akula, that must not work. You can try made like in schematic, but here is probarly wery small chance, that you get overunity. So I not wery see reason wasting time anwering you questions about divice, who I belive that for you not works.
"[size=78%]is there a convention for CW and CCW notation?"[/size]
This question I not understand, if try answer questions.
"[size=78%]Is the kacher HV coil the same as the first layer? or the outer layers?"[/size]
[size=78%]This also. Kacher, I think probarly have 500-1000 turns, and then 3 turns of tick wire at end to fix it, if you about that giving question.[/size]
I have no contact to(for) akula ....
I'll add a picture for the CW/CCW question; probably doesn't matter; because it's AC.
"nd then 3 turns of tick wire:" okay that's the ??? marked in the picture... that's what I thought too.
Regarding synchronization; perhaps in this scheme there is a sync.  The Kacher runs at a fixed frequency and is itself opposing, with a small delay though the middle variable inductor...
added circles and arrows for the various parts... while yes it is one conductive path, it is indicated in 3 parts on the schematic....
NickZ
  Tectron:  Thanks for ordering the Zeners for me.
   All:  If any of you are willing to work together towards back engineering the second Akula device, you can count me in on it.
   What is probably in the boxes that he doesn't want to show us are the circuits that control the duty cycle, and frequency controls for both the Exciter HV as well as the yoke circuits. Maybe someone can ask Akula if he is willing to show the inside of those boxes, and explain what is involved there. And if the circuits schematics that have been presented for that device are correct, or useful for our replications.
   I know that Akulas original intention was not to disclose the working principals of his first two circuits, but that seams to be changing as time goes on.
  As Akula's second device works as has been shown (and verified), it may be worth our while to see if we can also obtain similar results of some kind, even if not exactly like what he is showing. As even being able to light a single 100 watt bulb (without an external input source) is more than has ever been done by any of us here, previously.
  MenofFather: your comments are very important, as well as helping with the translations.  My thanks to you.
d3x0r
So then my question about direction was... is the kacher high voltage coil the same as the long first layer (indicated as CCW) or the same as the over layers (indicated as CW)?
d3x0r
Quote from: NickZ on June 21, 2014, 02:19:34 PM
I think that in the blank box is just the filter/capcitors/diodes and interconnections.  The other box(with toroid on top) is the TL494 driver.
It may contain a second TL494 with a small step-up transformer...
I started thinking about the opposing, layered currents and was reminded of a Birkland Current lecture.... Dr. Donald Scott: A New Model of Magnetic Structure in Space | EU20
Espcially at 9:26   or 19:58 or 31:40 He's kind of a slow talker... so there's only a little information in the 35:00 video... But he indicates there are multiple shell currents of free space electron flows...
d3x0r
I appreciate the feedback... it may not matter the orientation of that coil vs the others since it's an AC pulse and both sides will be equally represented... (And even for an english speaker I don't phrase things right so thanks for bearing with my poor asking :) )
The gauge of brown varnished wire seen coming off in the picture is rather low... 20-24 probably... and in that amount of length (about 15cm) there's no way you could have 500-1000 turns... 200 is a more appropriate count with 24 gauge wire (mine spans about 15cm).
