0 Members and 187 Guests are viewing this topic.
d3x0r
Quote from: NickZ on June 22, 2014, 12:33:32 AM
  I'm not sure I understand what "alternatives" you are talking about, which I should consider. As I have not seen any devices made by you or suggested by you, nor have I heard of any other alternatives, either. Other than your mentioning that the Akula device is "just a kacher".
If that is what you think, fine. But, Here (below) is where the original idea of the Brovin Kacher comes from, which was a high voltage but low amp circuit, unlike Akulas much more complicated high amp output type of circuit.
   https://www.youtube.com/watch?v=xMiNnHzFsRQ
I didn't say 'just a kacher'.
what I did say http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg407419/#msg407419
https://www.youtube.com/watch?v=IpmxooGBxfw
https://www.youtube.com/watch?v=kDLgX6vMrmM
https://www.youtube.com/user/3zdayz/videos   ... hmm I'd say at 1 year; but there's bad resolution on times there... take your pick on things I've done.
I'm not arguing, I'm just noting that like Observer, you're not very observant.
I wasn't aware I needed to present a resume before being read.
Edit:
Akula ruslan WIP
https://plus.google.com/106503144436194360259/posts/RkqzUwBDPBd
magpwr
Quote from: x_name41 on June 21, 2014, 05:21:13 PM
my topic on a bulgarian mazeto forum: http://mazeto.net/index.php?topic=9026.msg61422#msg61422
hi x_name41,
I have read the translated posting from you in Bulgarian forum.
I saw that you have made an attempt to replicate Ruslan work and got some interesting outcome for the basic  test circuit setup using the yoke core.
After reading through via the google translation i understand that the frequency you used is 73khz with below 3amps current drawn with 220/230volts 500watt or 250watt halogen bulb as load.
I understand you are using ATX to obtain 12volts or more than 12volts to power the 7812 voltage regulator.
Please do advise us what is the voltage going to yoke core primary transformer is it 12volts or 24volts from +12 -12v ATX power supply.
I more keen to know the input voltage and the estimated current draw if it is below <40watt to power Halogen bulb.
I understand RF is  one of  key factor to get the bulb lit.
I am currently working to replicate Don Smith China device currently redesigning my pcb circuit for the 3rd time to fit 6 x CREE IGBTs in a nice formation to fit within Letter size transparency.
http://www.youtube.com/watch?v=vowN5BFGW1c
Refer to PJKBOOK.PDF 2014 EDITION Page 260 and need to translate chinese forum.
Base on forum i understood high voltage and high frequency around 220khz...230khz is a important requirement they are using variable 500volts...1600volts from charge capacitors 4 x in series 450volts 220uf to get  1800volts 55uf capacitor.
This is switched via 6x 1200volts IGBT in series which IGBT drain is connected to 1nf to primary coil and another end of primary coil eventually leading to capacitor bank positive terminal.
magpwr
00
d3x0r
Quote from: 00 on June 22, 2014, 03:04:10 AM
kapanadze pattern
oo
which actually goes back to Stivep1's videos and his caduceus with a foil across 2 of the winding cross points.... each wire crosses points in the caduceus coils....
